removing passenger air bag
_Shane_
Got 3 defi gauges and a carbon dash pod to replace the passenger side airbag, how do i go about removing this ?
Seen a few members on here with the gauge display mounted
in the passenger air bag section but cant remember who exactly.
Cheers guys
Easy. Unscrew the lower glove box and poke your head up, you'll see where the airbag unit is mounted to the crash bar. 4 bolts. Then gently push it up and you'll see the yellow connector block, it has a white clip you have to flip up, then you just pull the plug out. Make sure you disconnect the battery before hand and handle it with care. ;)
Get your camera rigged up just incase it does blow! :D
on a serious note, be carefull! dont put it on the floor or surface with the airbag facing down, have you seen one fly?! WOW!
I put one in a microwave once. :taped:
In fact, I think Robsheffield was visiting at the time, and stood 50 odd metres away looking quite perplexed!
