Apexi AVCR -- Tuning Guide
Jellybean
Used the tuning guide on the website below but just wanted to let you know what I found with regards the NE Points, the guide says not to include the 4000 marker
http://www.mkiv.com/techarticles/avc-r/advanced_tuning.html
**I would include the 4000 marker because during the transition stage to the 2nd turbo I found the car hesitated and just sat there for a few seconds (when u need the power to over take), including the 4000 marker cured this
NE Points:
Definition/Usage: NE Points (a.k.a. RPM points) are used by the AVC-R to control boost at specific RPM's.
Recommended NE Points: (Assuming you're on stock twins using Sequential setup)
2000
2500
3000
3500
4500
5000
5500
6000
