HID in UK spec glass
NeoFuture
I did do a search but times have changed and prices and tech..
i have a 2008 merc with HID and they are awsome, my supra after body shop is having UK glass headlamps,
does anyone know what kit i need for both dipped and main beam ? or what fitment the bulbs are for part no, 81170-1B210 and 81130-1B210 shells ?
if i know the bulbs i can get the kits i spose...
Guest gzaerojon
Is main beam a good idea though? Don't forget they take a while to warm up, so a quick flash really won't be very bright, and also they may not last as I'm not sure if the ballast could take it
I changed the low beams (9006) only to HID in UK lights. When I flash the headlights, both high and low beams flash - is this normal? I never noticed that previously, but perhaps I wasn't really looking for it before I installed the HID's.
yup, mine do that too...
Thanks.
Do you know if they did the same before you installed your HID's? I'm guessing they must have done because I can't really understand how this could change by just plugging in the HID's...
as far as I am aware they've always been like that.. :D
I only noticed this the other day after fitting my HID's. I can't believe I never noticed it before :rolleyes:
