SteveC Posted April 1, 2009 Share Posted April 1, 2009 Looking for a good aircon condenser. Must be in good nick - already have one with a slow leak! Link to comment Share on other sites More sharing options...
SteveC Posted April 2, 2009 Author Share Posted April 2, 2009 ^^^^ Link to comment Share on other sites More sharing options...
Nic Posted April 3, 2009 Share Posted April 3, 2009 I can supply a brand new one. Link to comment Share on other sites More sharing options...
SteveC Posted April 3, 2009 Author Share Posted April 3, 2009 Thanks Nic. Please let me have a price when you have chance. Link to comment Share on other sites More sharing options...
SteveC Posted April 4, 2009 Author Share Posted April 4, 2009 ^^^^ Link to comment Share on other sites More sharing options...
n boost Posted April 5, 2009 Share Posted April 5, 2009 I might have one, do u have a pic of what it looks like and where it is mounted? Link to comment Share on other sites More sharing options...
SteveC Posted April 5, 2009 Author Share Posted April 5, 2009 Thanks for the reply. The aircon condenser (or 'condensor', as many call it) is mounted right in front of the car's water cooling radiator and it looks like a small radiator. Link to comment Share on other sites More sharing options...
n boost Posted April 5, 2009 Share Posted April 5, 2009 Sorry dont have that, sold it a while ago. Link to comment Share on other sites More sharing options...
SteveC Posted April 5, 2009 Author Share Posted April 5, 2009 Oh well, thanks anyway. Link to comment Share on other sites More sharing options...
SteveC Posted April 9, 2009 Author Share Posted April 9, 2009 ^^^^ Link to comment Share on other sites More sharing options...
wile e coyote Posted April 10, 2009 Share Posted April 10, 2009 I have one its not prity ,as far as im aware it dont leak You going japfest? pm me if so and ill stick it in the boot Link to comment Share on other sites More sharing options...
SteveC Posted April 10, 2009 Author Share Posted April 10, 2009 Thanks for the reply. I'm looking for as close to a minter as possible really - one that definitely doesn't leak and has all the fins fairly intact. If yours doesn't look pretty, then it sounds as though it may not be much better than what's on the car already. Thanks anyway. The one that's on the car at the moment doesn't leak too badly - it'll last a good 6 months or more, so I don't want to take a chance on something that could well be worse. The Japfest looks good. Pity it's almost 250 miles away for me... Link to comment Share on other sites More sharing options...
wile e coyote Posted April 10, 2009 Share Posted April 10, 2009 Ok mate just buy a new one or recon your old one Link to comment Share on other sites More sharing options...
jevansio Posted April 10, 2009 Share Posted April 10, 2009 I have one that came off my '97 facelift, it was in great condition & had no leaks, I will take pics for you tomorrow. The only thing is when I removed it I went on a bit of a hacking spree so I don't know if I've damaged any pipes running to/from it. The pics will reveal all tomorrow Link to comment Share on other sites More sharing options...
SteveC Posted April 10, 2009 Author Share Posted April 10, 2009 I have one that came off my '97 facelift, it was in great condition & had no leaks, I will take pics for you tomorrow. The only thing is when I removed it I went on a bit of a hacking spree so I don't know if I've damaged any pipes running to/from it. The pics will reveal all tomorrow Sounds good... apart from the 'hacking spree' bit! Hopefully the actual condenser will be ok. Link to comment Share on other sites More sharing options...
jevansio Posted April 10, 2009 Share Posted April 10, 2009 Lol, yeah , when I removed it I didn't realise it would be of any use to anyone else. I hacksawed some of the thin pipework to ease removing it, hopefully the pics tomorrow will show if it's of any use to you Link to comment Share on other sites More sharing options...
jevansio Posted April 11, 2009 Share Posted April 11, 2009 Steve, here's some pics, I don't think I actually damaged any pipes that you couldn't reuse from your setup. Only a small patch has bent fins, the rest is in pretty good condition for a 10 year old rad. The only bit I will draw you attention to is the bits I bent along the bottom where the rubber feet attach (although I imagine they will bend back into shape). Let me know what you think or if you want any more photos Link to comment Share on other sites More sharing options...
SteveC Posted April 11, 2009 Author Share Posted April 11, 2009 Thanks for the photos. Apart from the lower mounting points (I assume the rubber feet off my aircon condenser will simply attach/bolt on once straightened up?), it does appear to be in better condition that what's on my car at the moment. One query: Where the refrigerant connection is showing the green leak marker dye (I assume that's what it is) in the 5th photo, does some sort of gasket go in between there and the pipework? It doesn't show one in the parts diagram. Let me know what you're after for it (here, or via PM) and we'll take it from there. Thanks again, Steve. Link to comment Share on other sites More sharing options...
jevansio Posted April 11, 2009 Share Posted April 11, 2009 No worries, the rubber feet from yours should work but I will include my rubber feet also. I also have the pipe which bolts to the area you mention (it has a built in rubber seal), I will chuck that in If you could cover postage that'd be great, PM me your addy & I will get a box from work next week & get it sent Jay Link to comment Share on other sites More sharing options...
SteveC Posted April 11, 2009 Author Share Posted April 11, 2009 Brilliant! PM sent. Link to comment Share on other sites More sharing options...
SteveC Posted April 25, 2009 Author Share Posted April 25, 2009 It arrive today Jay and I'm very pleased with it. Thanks again. Steve. Link to comment Share on other sites More sharing options...
jevansio Posted April 25, 2009 Share Posted April 25, 2009 Good stuff bud Thank you Jay Link to comment Share on other sites More sharing options...
