Timing Belt Question
JamesC
Is there such a thing as a timing belt 'kit'? What would this include, just the belt and the tensioner?
If i order a timing belt, timing belt tensioner, crank pulley and aux belt will that cover everthing that should be done when down there?
Is Steve Manley the best place for discounted OEM parts?
Cheers.
You could change Idler Pulley part no. Y13505-46041 about £56.41 + vat from Steve, but for the Crank Pulley you are better off buying from Paul at Whifbitz, much cheaper.
For the pulley, cambelt and the pulley bolt came to £195.00 plus postage from Paul.
Cheers.
Edit: I didn't realise the exchange rate was that bad.
I got my coilpacks from Curt Aigner over in the States, it was much cheaper than over here even with the more expensive shipping.
http://www.supraforums.com/forum/forumdisplay.php?f=100
Edited by merckx (see edit history)
