Emu ultimate problems
michel lane
I have an emanage ultimate and having alot of problems getting it to fire up. I have checked the jumper setting according to Ian C and the are set , wiring has been checked over , but still getting no crank / rpm signal . Is there something i am over looking ? Car starts on stock ecu and emanage blue , but wont start on emanage ultimate . Is there something in the software that i have to change ? I seem to have the same problem as HODGE .....DOES ANYONE have one of these units installed ?? if they have i dont suppose they could plug it into there car and test it for me to make sure its not the unit thats faulty ?? should not be it was new.
thanks
I have an ultimate installed that i could easily swap over if you need a hand but i'm a bit of a way off to check it out unless you want to post it over.
also not to hijack the thread but anyone know what colours the rpm and speed signal wires are on the greddy loom at all, if i can find out i can plumb my profec into it :D
