hadyn Posted March 27, 2009 Share Posted March 27, 2009 Is it worth removing the headlight if you have a aftermarket cone air filter fitted to your car for drag-racing? Will the car actually make more power/better cooling? Or will the aerodynamics be screwed up with the headlight out? Car is fairly stock Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 27, 2009 Share Posted March 27, 2009 I would say no point on a BPU/Stock car, they stock system is actually very good and feeding air to the right places, it does help with a big single, that benifits from a lot of forced cool air coming into the engine bay on the drivers side Quote Link to comment Share on other sites More sharing options...
hadyn Posted March 27, 2009 Author Share Posted March 27, 2009 I would say no point on a BPU/Stock car, they stock system is actually very good and feeding air to the right places, it does help with a big single, that benifits from a lot of forced cool air coming into the engine bay on the drivers side When you say stock system do you mean with the airbox still in place? I have a cone filter with the two stock air feeds still in position Quote Link to comment Share on other sites More sharing options...
Scott Posted March 27, 2009 Share Posted March 27, 2009 I would say no, if you wanted a good benefit you would be better with a modified headlight to have the hole through it. My reason for thinking this is if you take out the headlight you will ruin the aerodynamics of the car. The wind resistance will skyrocket. With BPU it would probably cancel out any gains you would get from the cold air. However, if you only make a hole in the headlight, you will get the advantage with the cold air while only causing a bit more resistance. Quote Link to comment Share on other sites More sharing options...
hadyn Posted March 27, 2009 Author Share Posted March 27, 2009 My reason for thinking this is if you take out the headlight you will ruin the aerodynamics of the car. The wind resistance will skyrocket. With BPU it would probably cancel out any gains you would get from the cold air. . I think (despite having no scientific knowledge about this) I would agree with you mate. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 27, 2009 Share Posted March 27, 2009 When you say stock system do you mean with the airbox still in place? I have a cone filter with the two stock air feeds still in position Yes stock system, if you have removed the stock ducting then the removal of the light for a forced cool air effect may help, not a lot in it for a stock set up though I would have thought Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted March 28, 2009 Share Posted March 28, 2009 Why don't you try making an airbox for your filter and a cold air feed to a high pressure area in the car or somewhere with you can get a ram-air effect, might not give you much power but the reduction in vacuum in the induction system could offset the obstruction caused by your filter. Quote Link to comment Share on other sites More sharing options...
NeoFuture Posted March 28, 2009 Share Posted March 28, 2009 the lights are needed for aero dynamics, if you take em out you will cause an air lock and cause issues with the lines of the car, unless you intend to use dummy lights ? Quote Link to comment Share on other sites More sharing options...
ChrisB Posted March 28, 2009 Share Posted March 28, 2009 I tried it when i was doing lots of drag racing time was the same within .01 second (slower) so not really worth it in bpu Quote Link to comment Share on other sites More sharing options...
hadyn Posted March 28, 2009 Author Share Posted March 28, 2009 Thanks for your help guys Quote Link to comment Share on other sites More sharing options...
Pete Posted March 28, 2009 Share Posted March 28, 2009 I've heard it'll give you an extra 75 bhp! (but only if you do the resister trick) Quote Link to comment Share on other sites More sharing options...
