Changing my cambelt
Stratty
My J-spec NA is going for its first service next week and I have asked they guy to change the cam belt as well as it appears it was last done 5 years ago.
Can you tell me if all the cam belts are the same between the different models of car?
The guy at the garage said they only had TT ones and that it should be the same but I just wanted to check.
I didnt know if there would be a difference between a J-spec and Uk spec also.
many thanks.
They will be the same for both TT and NA applications. I'd go with a genuine Toyota one. It might be worth your while checking the crank pulley while its out and getting a new pulley bolt.
yeah, the guy did actually say something about the crank pulley and he is ordering the 'special tool'.
Sounds as though he has it in hand then.
Thanks
