Part Number Queries/Duplicates
dandan
Can anyone shed any light on the following please?
I have been looking at lots of parts to buy and have a few questions about certain parts that seem to have more than one part number.
I'm after stuff for a 1996 RZ TT Six Speed with Torsen Diff
Rear Suspension
48730-14040 or 48730-14030 for ARM ASSY, REAR SUSPENSION, NO.2 RH
48740-14070 or 48740-14060 for ARM ASSY, REAR SUSPENSION, NO.2 LH
Front Suspension
48610-19025 or 48610-29046 for ARM ASSY, FRONT SUSPENSION UPPER, RH
48630-19025 or 48630-29046 for ARM ASSY, FRONT SUSPENSION UPPER, LH
48068-14080 or 48068-14090 for ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 RH
48069-14080 or 48069-14090 for ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 LH
48190-14010 or 48190-24040 for CAM, FRONT SUSPENSION CAMBER ADJUST, NO.1 RH
Steering
45503-39015 or 45503-59015 for END SUB-ASSY, STEERING RACK NO.1
Rear Driveline
04437-24030 or 04437-24031 for BOOT KIT, REAR DRIVE SHAFT INBOARD JOINT
Any ideas?
Cheers
Dan
Rear Suspension
Front Suspension
I looked at a few of the above and the difference is the lower numbers are from 93/05 - 96/05. Then from 96/05 onwards.
Steering
This was substituted with 45503-39095
Rear Driveline
Appears to be just a substitution
Any ideas?
Cheers
Dan
Bold replies to your text.
Can you confirm if your chassis number is less than 0035274? There seems to be a revision after that date.
The part numbers you have are a bit mixed up, but if you confirm above I'll go through them
The rear suspension ones are mixing up link arms and lower suspension arms.
Sorry Homer - just saw your reply.
My number is in the region of 0036XXX.
The numbers came from the ToyoDIY pages originally. I'd be very grateful if you could point out which are correct for that chassis number.
Edit: Colsoop has already confirmed that I think...looks like I need the higher numbers?
Received your PM Dan, here's what my epc is showing as the correct numbers. I don't trust this though as Cols information differs slightly.
Rear Suspension
Front Suspension
Neither are correct on the adjuster. Can you confirm these are the compbined bolt/cam adjuster ones that secure the lower arm? There's two on each arm so two part numbers needed
Steering
Neither appear to be correct, mine shows 45503-39095. That seems to be an internal part of the steering rack - the rod that comes out the rack with the thread on it that the tie rod connects to.
Rear Driveline
I'll try this in sections...
All the images are from the online EPC and I've circled the necessary items in MS Paint :D
The text extracts are a copy paste from the right hand side of the online EPC page (of the items that crop up when you highlight the circled part in the image)
Steering:
45503A END SUB-ASSY, STEERING RACK NO.1
45503‑39095 JZA80 2 $134.46
45503‑59015 JZA80 2 $121.03
Edited by dandan (see edit history)
Rear Suspension Arms (working from top arm in a clockwise sense on attached image):
48770A ARM ASSY, UPPER CONTROL, REAR RH
48770‑19025 JZA80 1 $391.62
48790 ARM ASSY, UPPER CONTROL, REAR LH
48790‑19025 JZA80 1 $391.62
___________________________________________________
48730F ARM ASSY, REAR SUSPENSION, NO.2 RH
48730‑14030 JZA80 1 $253.78
48730‑14040 JZA80 1 $201.90
48740F ARM ASSY, REAR SUSPENSION, NO.2 LH
48740‑14060 JZA80 1 $253.78
48740‑14070 JZA80 1 $201.90
48780A ROD ASSY, STRUT, REAR
48780‑14030 JZA80 2 $133.61
48780‑14030 JZA80..GZ, RZ, RZS, SZR 2 $133.61
48720A ARM ASSY, REAR SUSPENSION, NO.1 LH
48710‑14110 JZA80 1 $144.20
48710A ARM ASSY, REAR SUSPENSION, NO.1 RH
Rear Suspension Cam Adjusters bits for bottom arms (from left to right on attached image):
48194G CAM, REAR SUSPENSION CAMBER ADJUST, NO.1 RH
48190‑22021 JZA80 1 $11.64
8198G CAM, REAR SUSPENSION CAMBER ADJUST, NO.1 LH
__________________________________________________________
48198H CAM, CAMBER ADJUST, NO.2
48198‑14010 JZA80 4 $6.66
48194H CAM, REAR SUSPENSION CAMBER ADJUST, NO.2 RH
48190‑24030 JZA80 1 $12.76
48198R CAM, REAR SUSPENSION CAMBER ADJUST, NO.2
Front Suspension Arms (top and bottom):
48610 ARM ASSY, FRONT SUSPENSION UPPER, RH
48610‑19025 JZA80 1 $392.05
48610‑29046 JZA80 1 $356.20
48630 ARM ASSY, FRONT SUSPENSION UPPER, LH
48630‑19025 JZA80 1 $392.05
48630‑29046 JZA80 1 $356.20
48068 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 RH
48068‑14080 JZA80 1 $359.51
48068‑14090 JZA80 1 $593.23
48069 ARM SUB-ASSY, FRONT SUSPENSION, LOWER NO.1 LH
48069‑14080 JZA80 1 $359.51
48069‑14090 JZA80 1 $593.23
Front suspension cam adjusters (left to right on attached image):
48194D CAM, FRONT SUSPENSION CAMBER ADJUST, NO.2 RH
48198‑24010 JZA80 2 $9.73
48198D CAM, FRONT SUSPENSION CAMBER ADJUST, NO.2 LH
___________________________________________________________
48194C CAM, FRONT SUSPENSION CAMBER ADJUST, NO.1 RH
48190‑14040 JZA80; フロント 1 $16.67
48190‑24020 JZA80; リヤ 1 $16.17
48198C CAM, FRONT SUSPENSION CAMBER ADJUST, NO.1 LH
My info is based on a rz 6 speed from 07/96
The above numbers are fine
48730‑14040 JZA80 1 $201.90 - 96/05 onwards
48740‑14070 JZA80 1 $201.90 - as above
Numbers are fine
Rear suspension arms
When i check the EPC for revisions it states vins from 0035--- onwards.
Number is fine
FINE
Number is fine
rear suspension cam adjusters
48068‑14090 JZA80 1 $593.23 - unlucky :p
Front suspension arms
I wonder what they did with the revision to increase the price by $200 ?
Number is fine
Numbers are fine
Numbers are fine
Numbers are fine
Front suspension cam adjusters.
Steering:
Thats it i think.
Thanks Col - I really appreciate you going through that mate.
I'm just cross referencing that with a fax from Steve Manley now to see how much it's all going to cost me!!!!!!!!!! :D
No problem.
I imagine over £1k plus fitting and alignment. But some spend more than that on bodykits and paint, i know which i would prefer :D
  • 6 years later...
