Boost gauge advice
nickball75
Ive just bought a second hand apexi mechanical boost gauge. It has the power leads but the vacuum pipe is missing. What length would be required as most places supply it in meters. Also should there be any connection piece? if so, what should I be buying?
if gauge is going in centre vent or where clock is.you will need 1.5 metre length to take you to centre of engine,where a t-piece will be needed to plumb in
