nickball75 Posted March 25, 2009 Share Posted March 25, 2009 Ive just bought a second hand apexi mechanical boost gauge. It has the power leads but the vacuum pipe is missing. What length would be required as most places supply it in meters. Also should there be any connection piece? if so, what should I be buying? Quote Link to comment Share on other sites More sharing options...
merckx Posted March 25, 2009 Share Posted March 25, 2009 Will you be fitting the gauge, if you are the length will obviously depend on where you're going to mount the gauge? You''l need a T piece for plumbing it in to the existing vacuum hose. Quote Link to comment Share on other sites More sharing options...
glenn Posted March 25, 2009 Share Posted March 25, 2009 Ive just bought a second hand apexi mechanical boost gauge. It has the power leads but the vacuum pipe is missing. What length would be required as most places supply it in meters. Also should there be any connection piece? if so, what should I be buying? if gauge is going in centre vent or where clock is.you will need 1.5 metre length to take you to centre of engine,where a t-piece will be needed to plumb in Quote Link to comment Share on other sites More sharing options...
nickball75 Posted March 25, 2009 Author Share Posted March 25, 2009 yeah, going to put it where the clock is. Thanks, thats all my questions answered, cheers chapies [GRIN][/GRIN] Quote Link to comment Share on other sites More sharing options...
