Chris Wilson Posted March 25, 2009 Author Share Posted March 25, 2009 I don't have the cables, no. have you got any contacts for these? I seem to now have 2 cars with a Stack on one and the Pi on this new one, with no cables I have to admit I prefer analogue instruments, heathen that I am Link to comment Share on other sites More sharing options...
bondango Posted March 25, 2009 Share Posted March 25, 2009 Damm you Chris!! i dont think i could squeeze into that!! is it the Cosy 3 litre? being an anarak i can tell you that Hitoshi Ogawa drove a T91 in the Japanese F3000 around 91' lol Link to comment Share on other sites More sharing options...
heather1mee Posted March 25, 2009 Share Posted March 25, 2009 looks well! Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 27, 2009 Author Share Posted March 27, 2009 looks well! Thanks, found a few inevitable problems. I knew when I bid on it, it had a couple of engine water leaks, these could have been trivial or more serious, it was a risk. Traced them under a pressure test to O rings on the rad pipes to the two water pumps (one for each bank). I have ordered new ones and cleaned up the housings. I had to remove these anyway as I wanted to weld on some adaptors to use an engine pre heater to get the thing close to running temp, coolant wise, before starting it, so no big deal. I suspect the fuel tank, which is an Aerospace "rubber" bag tank, may be leaking. There's a fuel smell, and it doesn't seem to like holding pressure. You can't go mad, 1.5 PSI is all that's safe to put in them, much more and they can split the tub open pneumatically. This could be a big problem as Premier would have to make a new one, which would be about 3 grand. Here's hoping... I also found the usually floor damage from kerbing to the underfloors, all very repairable, although I know where I can buy new ones if needed. A few of the bonded in alloy bobbins in the underside of the tub that take the sub floor bolts are stripped, or have wonky threads, these need sorting. Otherwise it seems very sound, with compressions OK and leakdowns good for the hours it's done. All the master cylinders, calipers and discs were renewed or rebuilt only 1.5 hors run time ago, so they are fine. The transaxle has had a recent rebuild, too. The suspension was also crack tested. The dampers were rebuilt by Koni and dyno tested a couple of hours run time ago, so no problems there, hopefully. I am trying to find oil filters for it (two small paper elements within the pressure pump itself, probably off something mundane, but also the same as the Zytek KV current engine if I can't match them, but Zytek will know how to price oil filters It's now very hard to buy new Mugen MF308 engine parts. I have ordered new harnesses, as these are out of date time. Willans still have the drawings as I could still read them the production code on the buckle strap, so not too bad at 200 notes a set. I can't run it without renewing these, although the ones in it have done sod all Some pics of it with the floors off and the wheels off, on its stand: http://www.chriswilson.tv/T91_2/lola2.html Link to comment Share on other sites More sharing options...
RobSheffield Posted March 27, 2009 Share Posted March 27, 2009 I like that it has a really big wing on the back, but i see your calipers are not actually anodized purple or red. I feel that is a drawback Do you have neons on the bottom? That would be trick Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 27, 2009 Author Share Posted March 27, 2009 With a maximum 30 mm ride height I'd need some very slim neons, in a very tough material, I'll pass on those I will have a flick through the anodising colour cards though, good idea Rob Link to comment Share on other sites More sharing options...
RobSheffield Posted March 27, 2009 Share Posted March 27, 2009 With a maximum 30 mm ride height I'd need some very slim neons, in a very tough material, I'll pass on those I will have a flick through the anodising colour cards though, good idea Rob In all seriousness, it looks awesome, im very jealous If you need a skinny driver with lightening fast reflexes to do the vehicle justice then give me a call.... ...wont be me though! Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 27, 2009 Author Share Posted March 27, 2009 We'll see how we manage with a short fat one, with slow reflexes, for now I never knew HKS uses a T91 as a mule for their short lived V12 F1 engine attempt... It's even the same colour as my car! Link to comment Share on other sites More sharing options...
SteveR Posted March 30, 2009 Share Posted March 30, 2009 Any idea how loud it'll be WOT Chris? Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 30, 2009 Author Share Posted March 30, 2009 Well I fired it up on Friday and despite living in the sticks I had people from way down the lane come over to see what the hell was happening, so, IMHO, it's bloody loud, and i was only blipping it to about 4000 RPM It also seems to have a bag tank leak, which is an expensive PITA Link to comment Share on other sites More sharing options...
Wez Posted March 30, 2009 Share Posted March 30, 2009 Well I fired it up on Friday and despite living in the sticks I had people from way down the lane come over to see what the hell was happening, so, IMHO, it's bloody loud, and i was only blipping it to about 4000 RPM It also seems to have a bag tank leak, which is an expensive PITA What does it idle at and how high does it rev? Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 30, 2009 Author Share Posted March 30, 2009 It'll probably idle about 2000 and it is rev limited at 9000, but that was to meet the regs in period, they can run to 10,000 but this one won't see that much (intentionally...) The tank doesn't seem to be leaking, it was the seal on on the anti syphon valve that had gone, thanks God. Link to comment Share on other sites More sharing options...
extendor Posted March 30, 2009 Share Posted March 30, 2009 God, that was a lot to wade through, but yes, that'll be the same car. it's an ex Heinz Harold Frentzen car, then run on the hills in Belgium. Busy making an adaptor to do a compression and leakdown test on it. 10mm x 1.0 plug size, down an 18 mm well. the plugs take a 1/2 inch socket. so they are tiny. Sounds like a marine engine plug to me. Link to comment Share on other sites More sharing options...
gordy07 Posted March 30, 2009 Share Posted March 30, 2009 Awesome bit of kit chris,well done finding that:) Link to comment Share on other sites More sharing options...
Gordon F Posted March 30, 2009 Share Posted March 30, 2009 I used to work on these things back in the day, though in 91 I was with a team running Reynard DFV's. Surprised to see that there are still some of these about, as they were 'pre plank' days and we used to run them very low and the chassis used to take an awful beating over the kerbs. Cracked and damaged tubs used to be very common, usually round the bulkheads and floor area. Also, we only used to run them for one season as we used to get new cars every year, though there was a British F2 series for older cars, and the Japanese would run these as well. Good luck with it Chris, would like to see it in action one day Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 30, 2009 Author Share Posted March 30, 2009 Got my eye on a brand new rolling chassis, never even been painted.... If I like it I might buy it ostensibly for spares, but possibly to build and use THIS one for spares. Tub seems very good, sub floors are a bit ratty, but having a neighbour who is a carbon specialist helps there. He has been round to have a look and can fix the worst one (centre floor) to be pretty good again for a modest fee. Link to comment Share on other sites More sharing options...
SteveR Posted March 30, 2009 Share Posted March 30, 2009 Well I fired it up on Friday and despite living in the sticks I had people from way down the lane come over to see what the hell was happening, so, IMHO, it's bloody loud, and i was only blipping it to about 4000 RPM It also seems to have a bag tank leak, which is an expensive PITA Where will you be able to use it? IIRC even 'loud' days have their limits? Maybe I could persuade Llandow to let you do some one-off, let's forget the noise limit, demo laps at the club track day. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 30, 2009 Author Share Posted March 30, 2009 Donington, Silverstone, plenty of European circuits still, although I don't i'd make the effort to drive across Europe for a few laps Llandow would sadly take the bottom out of it, it's too bumpy. Running costs are such that I won't be doing millions of laps so the limitations of where it can run aren't that bad to me. Link to comment Share on other sites More sharing options...
SteveR Posted March 30, 2009 Share Posted March 30, 2009 Donington, Silverstone, plenty of European circuits still, although I don't i'd make the effort to drive across Europe for a few laps Llandow would sadly take the bottom out of it, it's too bumpy. Running costs are such that I won't be doing millions of laps so the limitations of where it can run aren't that bad to me. Let me know when you go for an outing as I'd probably take a day off to come & spectate. Link to comment Share on other sites More sharing options...
