Ian C Posted April 3, 2005 Share Posted April 3, 2005 Name: Boost Gauge Also known as: n/a What is it? A gauge that displays, usually in PSI or Bar, the amount of boost pressure your intake manifold is seeing. The first bit of performance tuning you'll probably do to your Supra is increase the boost in some fashion. This can be by a bleed valve or a boost controller affecting the wastegate, or by a decat and/or performance exhaust pipe affecting the flow of the turbo. You *need* to know what's going on at this point, because the fastest way you can destroy an engine is to run too much boost. Another factor is that the stock sequential system can go wrong in various ways, or the airflow path to the engine can fail, usually due to hoses being loose, split, or plain old missing. The boost gauge lets you monitor the behaviour of the system across the rev range, which aids in troubleshooting the problem no end. Especially if you are asking questions in a text-based forum Pros: Shows you how much boost the engine is seeing Acts as a diagnostic tool Cons: You have to fit it somewhere. Either replacing the clock or a heater vent (depending on the gauge size) or getting an a-pillar pod, that sort of thing. Quote Link to comment Share on other sites More sharing options...
rik Posted December 4, 2006 Share Posted December 4, 2006 Some boost guages are mechanical, and are cheaper than the electrical types. What are the pros and cons of both? Quote Link to comment Share on other sites More sharing options...
TrickTT Posted December 4, 2006 Share Posted December 4, 2006 Mechanical Gauges Pros: Cheaper than electronic ones Cons: Less accurate. No extra features(ie warning/peakhold/replay). You have a direct vent from the inlet manifold into the cabin. Quote Link to comment Share on other sites More sharing options...
steb9780 Posted December 4, 2006 Share Posted December 4, 2006 Mechanical: Pro's Generally cheaper to buy, slightly less installation for wires etc. IMO I think there is less that can go wrong with a mech one. Con's Not as smooth a sweeping action as the electric ones, less functions i.e. peak hold warning etc. Sometimes very difficult to catch what full boost you get, whilst keeping your eyes on the road. Electrical: Pro's Smoother action than Mech, can come with peak hold functions and warning lights etc. Peak hold is very handy for safety, so you can give it a power run then slow, and use the peak hold function to see what boost was achieved. Con's More expensive usually, more installation needed, and IMO there are more things that can go wrong with one i.e. elctrical wire getting crushed/chafed etc. Hope that helps, anybody care to add anymore that I can't think of?? Quote Link to comment Share on other sites More sharing options...
alan_blue Posted December 7, 2006 Share Posted December 7, 2006 a fitting guide? Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 16, 2006 Share Posted December 16, 2006 http://mkiv.com/techarticles/boostguage/bg.htm Quote Link to comment Share on other sites More sharing options...
JMB Posted July 24, 2011 Share Posted July 24, 2011 Hi! Is the Hks evc-s boost controler a boost gauge too ? Quote Link to comment Share on other sites More sharing options...
