Supra handles like jelly
Ark
Chaps, got a bit of a problem we're trying to diagnose on a Supra that just handles like jelly - at about 50 mph it just wobbles and feels like it's going to break away. The wheels and tyres have been swapped over as a test. The shocks have been replaced (OEM replacements, one day old). There's no play in the the wheels, bearings or suspension arm bushes. No obvious geometry problems. The subframes are tight enough that we can't replicate any play in them on a ramp...
Please, anyone with any thoughts or suggestions of what to look at next, I'd love to hear about it.
Thanks.
How did you check suspension bushing play? Mine seemed fine to me but the guys at SCA used a breaker bar to level them around and that showed up how bad they were.
Imbalanced shocks can cause this but if you had them all replaced... The thing about spacers/hub centric rings is plausible, although that'd manifest more as a vibration like an imbalanced wheel I'd have thought.
Are the springs ok? Did you try different wheels entirely off a known good car, perhaps one tyre is deformed or the compound is too soft for some reasons and swapping the sides they are on wouldn't change the problem. Any play in the steering system?
-Ian
May sound stupid, but a friend of mine had a similar problem with his car a while back. It eventually turned out, that somehow the air hose he had used a while back had a problem, and when filling the tyres, had blown alot of water/moisture into the tyres. This then led to constantly unbalancing the tyres when driving above certain speeds.
I am not clear as to what you mean by, "The wheels and tyres have been swapped over as a test", but if you dont mean from another car then it's a suggestion.
My money is on worn out suspension bushes and joint, as Ian says you need to get a big breaker bar on them and check for play. If there is play replacing them will make a massive difference.
With the age and mileage of most Supras now there must be loads of cars out there with worn out suspension components.
Thanks for the input everyone. The wheels were borrowed off another Supra, known to be sound and stable so that's not the problem. I guess the next thing is to have a go at the bushes with a breaker bar then...
Thanks again. Will post up if we get anywhere with that.
