Ian C Posted April 3, 2005 Share Posted April 3, 2005 Name: Racelogic Traction Control Also known as: RLTC What is it? A motorsport level programmable traction control unit, with in-car adjustment of 'allowed' wheelspin (slip) levels via a control box. It works by instantly cutting the fuel injectors rather than the crapulous stock method of closing a throttle plate five seconds after the wheels started spinning. Pros: Great in the wet, almost a 'standard' upgrade for the Supra, will catch those moments that you might not. Still allows for fun with the selectable slip rates. Makes uber-powered Supras more fun to drive. Cons: Needs professional fitting, takes some calibration, and the software is not the easiest to use. Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 26, 2005 Share Posted June 26, 2005 Only requires professional fitting if you think you cant do it. If you can follow simple diagrams and solder in confined spaces, it will take about a day to fit properly. Quote Link to comment Share on other sites More sharing options...
