Heater problem (Maybe)
Blackie
this has just happend to my new one. its only blowing cold air.
i have blow through the maqtrix with regulated air line and it seems its flowing fine . both in and out pipes are red hot to touch after the car has run. but the air comeing out is still cold ? no leaks inside the car either.
any other ideas?
Mine just sorted its self Craig within a day or so
ok i have found the problem .
i have taken the top and bottom boxes out and found the rod in question and its all coneected up.
so i took my other supra apart and wathed what happend when i pressed buttons an twiddled knobs (lol)
it seems the motor is fuged when i turn the heater controll the arm dose not rotate and so dose not move the connecting rod. i tryed the dash pannel from supe 2 to see if it was the controll box that was at fualt but still no joy.
so. is there a fuse for the behind dash motor/temp controller and if not , im guessing its a full dash out job from the looks ?
