dani_r Posted March 22, 2009 Share Posted March 22, 2009 (edited) Afternoon chaps! Hopefully someone will be able to help me. I've been experiencing some vibration which I think is coming from the gearbox/prop shaft area (from the gear shifter area back towards the centre console). The vibration only happens when I get near the high end of the rev range and disapears when I change gear. Normal driving is ok, with no vibration. I've got a 93 5 Speed NA. Any thoughts? Cheers Dan Edited March 22, 2009 by dani_r (see edit history) Quote Link to comment Share on other sites More sharing options...
dani_r Posted March 22, 2009 Author Share Posted March 22, 2009 anyone? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 22, 2009 Share Posted March 22, 2009 Check the cv joints are good (not seized) Means removing the prop Quote Link to comment Share on other sites More sharing options...
dani_r Posted March 23, 2009 Author Share Posted March 23, 2009 CV Joints? I've had a look at the turbosupras manuals but couldn't see any reference to these (perhaps I wasn't looking in the right section ). What are these and how do I get to them? I'm off to the workshop now so I'll have a poke around. Quote Link to comment Share on other sites More sharing options...
dannysupratt Posted March 23, 2009 Share Posted March 23, 2009 Could very well be the centre bearing on the propshaft. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 23, 2009 Share Posted March 23, 2009 cv joints on either end of prop or as said centre bearing Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted March 23, 2009 Share Posted March 23, 2009 as above. Quote Link to comment Share on other sites More sharing options...
dani_r Posted March 23, 2009 Author Share Posted March 23, 2009 (edited) If the centre bearing is the problem then does that mean a new prop? Hang on, I'll have a look in the manual! Edited March 23, 2009 by dani_r (see edit history) Quote Link to comment Share on other sites More sharing options...
dani_r Posted March 23, 2009 Author Share Posted March 23, 2009 (edited) OK, so I've had a look. Is this what we're talking about? Would a worn bearing in this area account for the vibration? The manual on Turbsupras has a number of possibilities for vibration (if it is indeed the prop shaft where the problem lies) 1. Transmission extension housing rear bushing (Runout) 2. Sleeve yoke spline (Stuck) 3. Propeller shaft (Runout) 4. Propeller shaft (Imbalance) I don't have enough knowledge to know if my symptoms would be caused by any of these things, for example, what the hell is a yoke? Edited March 23, 2009 by dani_r (see edit history) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 24, 2009 Share Posted March 24, 2009 1. Transmission extension housing rear bushing (Runout) where the prop goes into gear box there is a bush 2. Sleeve yoke spline (Stuck) as the rear suspension moves you need movement back and forth , so a yoke alows one shaft to slide in and out of the other (shaft into flange) 3. Propeller shaft (Runout) think this is talking about the centre bearing 4. Propeller shaft (Imbalance) as it says Im sure if im wrong with any of these somebody will correct me Quote Link to comment Share on other sites More sharing options...
dani_r Posted March 24, 2009 Author Share Posted March 24, 2009 Well, most of the vibration seems to be coming from around the end of the gear box area/front of intermediate shaft sub-assembly area. Does anyone know if this is something I'd be able to have a look at by myself? I have ramp access. Or should I let someone else have a look? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 24, 2009 Share Posted March 24, 2009 I think get a transmission specialist to have a look mate Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 6, 2009 Share Posted April 6, 2009 Did you ever find the problem mate ? Quote Link to comment Share on other sites More sharing options...
dannysupratt Posted April 6, 2009 Share Posted April 6, 2009 If you take it to a garage they will should be able to check very quickly if the centre bearing is done for. And as far as im aware you can have a new one pressed on without changing the propshaft. 100 quid from toyota for the bearing. Quote Link to comment Share on other sites More sharing options...
dani_r Posted April 7, 2009 Author Share Posted April 7, 2009 No i haven't had a chance to look at it yet. I suspect the pressure plate is done. After fixing my clutch master cylinder I have been experiencing clutch slip, so I suspect the vibration was a precurser to the clutch failing. Can't say for definate though. Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted April 6, 2018 Share Posted April 6, 2018 No i haven't had a chance to look at it yet. I suspect the pressure plate is done. After fixing my clutch master cylinder I have been experiencing clutch slip, so I suspect the vibration was a precurser to the clutch failing. Can't say for definate though.Ever get to the bottom of this? Quote Link to comment Share on other sites More sharing options...
