locked out
Dan8
sorted now t a for or the help i did not recieve make you wonder why pay to be a member of a club which only gives advice to members that suites them and not those who always have the time to been on the forum or attend events
Did you not see the other thread you created that was moved to members? It had a load of replies with an explaination how to get into the car :search:
Obviously no one is going to explain in the public section how to break into a supra!!!
Edit: http://www.mkivsupra.net/vbb/showthread.php?t=180434
Which you've since posted in with the same response claiming no one helped, but there is an explaination from Dnk how to do it.
i was just wanting a quick way as it was sat running & i thought hang on i remeber reading a members car been broke into in an underground car park without any lock damage & there where several posts sent to them explaining how to do it was hoping i could of recieved similar which is why the forum was the 1st thing i thought of
I understand people not wanting to give out this information but i am paid member & have delt with other members sales without problem
never mind anyway i was just a bit fuming with it all & needed to let some out i do find the club helpfull & members go out there way for others
The trick you refer to IS the way to do it. I've done it myself and helped someone else do it. It's pretty easy, you just need a bit of patience which it seems you may be a bit short of.
Dan, Are you blind fella, it was explained how to get into it in the thread in members :D If that didn't work, then reply to the thread and let people know you were not able to do it, there are other options. The method works fine, done it a dozen times :D
BTW, I edited your post as this is in the PUBLIC section.
