lee_kelsey Posted September 24, 2002 Share Posted September 24, 2002 Guys, I have a new radiator top hose I need to fit, as my old one has begun to perish at one end. The only trouble is, I cannot find the bleed tap. I don't need to drain the system fully, although it would be nice, to freshen it up. Can someone tell me where I need to look or at least the best way to drain it. Cheers Lee Quote Link to comment Share on other sites More sharing options...
matt Posted September 24, 2002 Share Posted September 24, 2002 The rad drain is a plastic eared screw at the bottom right of the rad as you look down from the top facing the car. There should be a lil bit of pipe attached that pokes thro the undertray ... It is under the small elactric fan ..... have another look Theres another on the block somewhere but you won't need it for the top hose only HTH Quote Link to comment Share on other sites More sharing options...
lee_kelsey Posted September 24, 2002 Author Share Posted September 24, 2002 Thanks matt, will give it a go! Quote Link to comment Share on other sites More sharing options...
