kevlar_Soul Posted March 21, 2009 Share Posted March 21, 2009 Hello mates! I'll be changing my front seats this weekend and I really need some help with this shit. Can you please post some pictures at how you installed the new seats, everything is appreciated. How did you mount the chair? Into the standard attachments? Or did you create new ones? Please help this dirty swede right ahead! // Cim Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 22, 2009 Share Posted March 22, 2009 What seats are you installing ? Geting the old ones out is straightforward enough: passenger side: Slide the seat all the way back and remove the 2 front bolts (14mm ?) Now slide the seat all the way forward and remove the 3 rear bolts, 2 either side as up front and one set in to the transmission tunnel. Lift the seat up slightly and unplug the connection. It is the same operation on the drivers side although from memory there are 2 plugs on the drivers side and it is a lot heavier too so watch the sills and doors and your back Point to note: you will need power in order to move the drivers seat forward and backwards. Quote Link to comment Share on other sites More sharing options...
kevlar_Soul Posted March 22, 2009 Author Share Posted March 22, 2009 Thanks mate! So should I use the standard attachments to mount my new seats? The seats are similiar to the Sparco ones called Evo 2. How did you solve the problem with the seat belts on each side? Did you use the standard attachments or did you create new ones? Please post pictures!! Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 22, 2009 Share Posted March 22, 2009 Did your seats come with sub frames if not you will need to purchase those, the seatbelt is fixed to the Supra seat so you will need harnesses or to relocate the seatbelt clip and bolt it to the transmission tunnel Quote Link to comment Share on other sites More sharing options...
kevlar_Soul Posted March 22, 2009 Author Share Posted March 22, 2009 Pictures please??? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 22, 2009 Share Posted March 22, 2009 Pictures please??? Here you see the stock seat removed with the attached seat belt clip, asyou can see the entire seat and subframe are attached as one Here is my aftermarket seat attached the a separate Recaro sub frame which bolts to the existing holes in the floor and transmission tunnel This is the seat with a set of harnesses to avoid the need for the stock seat belt Quote Link to comment Share on other sites More sharing options...
