Ian C Posted April 3, 2005 Share Posted April 3, 2005 I've got a 6-speed Supra...what are the ratios? It should say on the VIN plate which gearbox you have (V160 or 161 - the 161 was introduced around the time VVTi was brought in, in 1997) Gearbox:- 2JZ-GTE V160 6-Spd Tyre:- equivalent to 235/45 x 17 Top Gear gives 28.210 MPH/1000 RPM and a top speed of 197.473 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1063 RPM 40 MPH = 1418 RPM 50 MPH = 1772 RPM 60 MPH = 2127 RPM 70 MPH = 2481 RPM 80 MPH = 2836 RPM 90 MPH = 3190 RPM 100 MPH = 3545 RPM Top Speed in 1 gear = 40.919 MPH And changes into 2 gear at 4317 RPM dropping 2683 RPM Top Speed in 2 gear = 66.354 MPH And changes into 3 gear at 4998 RPM dropping 2002 RPM Top Speed in 3 gear = 92.935 MPH And changes into 4 gear at 5450 RPM dropping 1550 RPM Top Speed in 4 gear = 119.357 MPH And changes into 5 gear at 5335 RPM dropping 1665 RPM Top Speed in 5 gear = 156.596 MPH And changes into 6 gear at 5551 RPM dropping 1449 RPM Top Speed in 6 gear = 197.473 MPH Gearbox:- 2JZ-GTE VVTI V161 6-Spd Tyre:- equivalent to 235/45 x 17 Top Gear gives 27.348 MPH/1000 RPM and a top speed of 191.438 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1097 RPM 40 MPH = 1463 RPM 50 MPH = 1828 RPM 60 MPH = 2194 RPM 70 MPH = 2560 RPM 80 MPH = 2925 RPM 90 MPH = 3291 RPM 100 MPH = 3657 RPM Top Speed in 1 gear = 42.050 MPH And changes into 2 gear at 4222 RPM dropping 2778 RPM Top Speed in 2 gear = 69.722 MPH And changes into 3 gear at 4803 RPM dropping 2197 RPM Top Speed in 3 gear = 101.620 MPH And changes into 4 gear at 5474 RPM dropping 1526 RPM Top Speed in 4 gear = 129.955 MPH And changes into 5 gear at 5809 RPM dropping 1191 RPM Top Speed in 5 gear = 156.596 MPH And changes into 6 gear at 5726 RPM dropping 1274 RPM Top Speed in 6 gear = 191.438 MPH And if I have a five speed box? Gearbox:- 2JZ-GE (NA) W58 5-Spd Tyre:- Michelin all patterns 235/45 x 17 Top Gear gives 22.854 MPH/1000 RPM and a top speed of 159.976 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1313 RPM 40 MPH = 1750 RPM 50 MPH = 2188 RPM 60 MPH = 2625 RPM 70 MPH = 3063 RPM 80 MPH = 3501 RPM 90 MPH = 3938 RPM 100 MPH = 4376 RPM Top Speed in 1 gear = 38.131 MPH And changes into 2 gear at 4036 RPM dropping 2964 RPM Top Speed in 2 gear = 66.136 MPH And changes into 3 gear at 4712 RPM dropping 2288 RPM Top Speed in 3 gear = 98.244 MPH And changes into 4 gear at 5490 RPM dropping 1510 RPM Top Speed in 4 gear = 125.261 MPH And changes into 5 gear at 5481 RPM dropping 1519 RPM Top Speed in 5 gear = 159.976 MPH And for UK spec diffs: Gearbox:- 2JZ-GTE V160 6-Spd w/UK DIFF Tyre:- Michelin all patterns 235/45 x 17 Top Gear gives 29.408 MPH/1000 RPM and a top speed of 205.856 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1020 RPM 40 MPH = 1360 RPM 50 MPH = 1700 RPM 60 MPH = 2040 RPM 70 MPH = 2380 RPM 80 MPH = 2720 RPM 90 MPH = 3060 RPM 100 MPH = 3400 RPM Top Speed in 1 gear = 42.656 MPH And changes into 2 gear at 4317 RPM dropping 2683 RPM Top Speed in 2 gear = 69.171 MPH And changes into 3 gear at 4998 RPM dropping 2002 RPM Top Speed in 3 gear = 96.880 MPH And changes into 4 gear at 5450 RPM dropping 1550 RPM Top Speed in 4 gear = 124.424 MPH And changes into 5 gear at 5335 RPM dropping 1665 RPM Top Speed in 5 gear = 163.244 MPH And changes into 6 gear at 5551 RPM dropping 1449 RPM Top Speed in 6 gear = 205.856 MPH Gearbox:- 2JZ-GTE VVTI V161 6-Spd w/UK DIFF Tyre:- Michelin all patterns 235/45 x 17 Top Gear gives 28.509 MPH/1000 RPM and a top speed of 199.564 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1052 RPM 40 MPH = 1403 RPM 50 MPH = 1754 RPM 60 MPH = 2105 RPM 70 MPH = 2455 RPM 80 MPH = 2806 RPM 90 MPH = 3157 RPM 100 MPH = 3508 RPM Top Speed in 1 gear = 43.836 MPH And changes into 2 gear at 4222 RPM dropping 2778 RPM Top Speed in 2 gear = 72.682 MPH And changes into 3 gear at 4803 RPM dropping 2197 RPM Top Speed in 3 gear = 105.934 MPH And changes into 4 gear at 5474 RPM dropping 1526 RPM Top Speed in 4 gear = 135.472 MPH And changes into 5 gear at 5809 RPM dropping 1191 RPM Top Speed in 5 gear = 163.244 MPH And changes into 6 gear at 5726 RPM dropping 1274 RPM Top Speed in 6 gear = 199.564 MPH -Alex Link to comment Share on other sites More sharing options...
carl0s Posted September 18, 2006 Share Posted September 18, 2006 Doesn't actually give the ratios there does it.. Link to comment Share on other sites More sharing options...
Lucifer Posted September 19, 2006 Share Posted September 19, 2006 6 Speed (V160) / (V161) 3.827 / 3.724 2.360 / 2.246 1.685 / 1.541 1.312 / 1.205 1.000 / 1.000 0.793 / 0.818 3.280 / 3.192 3.266(all TT) / 3.769(NA) 5 Speed (W58) 3.285 1.894 1.275 1.000 0.783 n/a 3.768 4.083(NA) Auto (A343E) 2.804 1.531 1.000 0.705 n/a n/a 2.393 3.769(TT) / 4.083(NA) Link to comment Share on other sites More sharing options...
Kirk Posted March 28, 2009 Share Posted March 28, 2009 What bout NAs with v161? Link to comment Share on other sites More sharing options...
SatSport Posted March 28, 2009 Share Posted March 28, 2009 as the majority are running 18`s is there a formula to calculate the new mph/1000rpm? Link to comment Share on other sites More sharing options...
merckx Posted March 28, 2009 Share Posted March 28, 2009 What bout NAs with v161? Same but the final drive is different. 3/4 down the page http://mkiv.supras.org.nz/specs.htm Link to comment Share on other sites More sharing options...
merckx Posted March 28, 2009 Share Posted March 28, 2009 as the majority are running 18`s is there a formula to calculate the new mph/1000rpm? It's the tyre diameter that counts and not the wheel. If the tyre diameters were the same it wouldn't matter if you had 16" or 20" wheels. Link to comment Share on other sites More sharing options...
