Ian C Posted April 3, 2005 Share Posted April 3, 2005 I've got an automatic Supra...what are the ratios? Gearbox:- 2JZ-GTE AUTO 4-spd Tyre:- Michelin all patterns 235/45 x 17 Top Gear gives 27.497 MPH/1000 RPM and a top speed of 192.478 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1091 RPM 40 MPH = 1455 RPM 50 MPH = 1818 RPM 60 MPH = 2182 RPM 70 MPH = 2546 RPM 80 MPH = 2909 RPM 90 MPH = 3273 RPM 100 MPH = 3637 RPM Top Speed in 1 gear = 48.394 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 88.633 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 135.697 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 192.478 MPH Gearbox:- 2JZ-GE (NA) AUTO 4-Spd Tyre:- Michelin all patterns 235/45 x 17 Top Gear gives 25.382 MPH/1000 RPM and a top speed of 177.676 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1182 RPM 40 MPH = 1576 RPM 50 MPH = 1970 RPM 60 MPH = 2364 RPM 70 MPH = 2758 RPM 80 MPH = 3152 RPM 90 MPH = 3546 RPM 100 MPH = 3940 RPM Top Speed in 1 gear = 44.672 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 81.817 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 125.261 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 177.676 MPH Thinking of putting a manual diff on an autobox? Here you go: Gearbox:- 2JZ-GTE AUTO 4-spd w/UK MANUAL DIFF Tyre:- Michelin all patterns 235/45 x 17 Top Gear gives 33.079 MPH/1000 RPM and a top speed of 231.551 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 907 RPM 40 MPH = 1209 RPM 50 MPH = 1512 RPM 60 MPH = 1814 RPM 70 MPH = 2116 RPM 80 MPH = 2418 RPM 90 MPH = 2721 RPM 100 MPH = 3023 RPM Top Speed in 1 gear = 58.218 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 106.625 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 163.244 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 231.551 MPH Gearbox:- 2JZ-GTE AUTO 4-spd w/JAP MANUAL DIFF Tyre:- Michelin all patterns 235/45 x 17 Top Gear gives 31.732 MPH/1000 RPM and a top speed of 222.122 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 945 RPM 40 MPH = 1261 RPM 50 MPH = 1576 RPM 60 MPH = 1891 RPM 70 MPH = 2206 RPM 80 MPH = 2521 RPM 90 MPH = 2836 RPM 100 MPH = 3151 RPM Top Speed in 1 gear = 55.847 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 102.283 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 156.596 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 222.122 MPH -Alex Link to comment Share on other sites More sharing options...
den1 Posted September 28, 2009 Share Posted September 28, 2009 This is very interesting! But Would anybody know how to correctly check the Auto Gearbox oil level? Does the engine have to be running? Or Static? Link to comment Share on other sites More sharing options...
Stephen G Posted September 28, 2009 Share Posted September 28, 2009 engine running Link to comment Share on other sites More sharing options...
den1 Posted September 28, 2009 Share Posted September 28, 2009 slutdog said: engine running Normal RPM Idle or Higher (1800 RPM) Link to comment Share on other sites More sharing options...
Terminator Posted September 28, 2009 Share Posted September 28, 2009 Hot box with normal idle. Follow the correct procedure exactly or you will get the reading wrong. Link to comment Share on other sites More sharing options...
den1 Posted September 28, 2009 Share Posted September 28, 2009 Is there a possibility of someone making a something like this a "Sticky" in the basic technical section. How to check the Auto Gearbox oil ( The correct procedure ) Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 den1 said: This is very interesting! But Would anybody know how to correctly check the Auto Gearbox oil level? Does the engine have to be running? Or Static? Procedure should be in service manual here: http://www.turbosupras.com/pages/en/pages/specifications/JZA80/a80tsrm.htm Link to comment Share on other sites More sharing options...
Kaan W Posted December 31, 2012 Share Posted December 31, 2012 Interesting... Has anyone tried a Uk spec manual diff on a GTE auto? Would it bolt up to the prop or is it a different flange? I am willing to test the acceleration difference if I can find one.... Link to comment Share on other sites More sharing options...
Josh42 Posted December 31, 2012 Share Posted December 31, 2012 The flange is different mate but you can mate the front half of the manual prop with the rear half of the auto prop..... Or get a custom prop made up:) Link to comment Share on other sites More sharing options...
Kaan W Posted December 31, 2012 Share Posted December 31, 2012 Josh42 said: The flange is different mate but you can mate the front half of the manual prop with the rear half of the auto prop..... Or get a custom prop made up:) Or the front half of an auto prop with the rear half of a manual prop If I can find a manual diff and prop cheap enough to modify i'll have to experiment. Also are the manual differentals stronger? Link to comment Share on other sites More sharing options...
Josh42 Posted December 31, 2012 Share Posted December 31, 2012 Yeah, that! Link to comment Share on other sites More sharing options...
Swampy442 Posted December 31, 2012 Share Posted December 31, 2012 Its the same diff, just a different ratio so no, not any stronger. Link to comment Share on other sites More sharing options...
tony tt Posted March 16, 2013 Share Posted March 16, 2013 Interesting. Off to look at manual diffs Link to comment Share on other sites More sharing options...
David P Posted March 16, 2013 Share Posted March 16, 2013 (edited) Before folks work out that none of them are rolling on 235 45 17's, these links might save a lot of lazy questions. http://www.willtheyfit.com/ http://www.differentials.com/technical-help/differential-gear-ratio-calculator Edited March 16, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
