120mph limiter
dodgydave13
It's the stock 112mph limiter, your speedo is reading incorrecty (or normal ;) ).
You'll need to fit a device to remove the limiter. There are many on the market, but be sure to use the correct one, many ebay ones will screw up the PAS rates (very dangerous).
There is a search button which will reveal this item being discussed a hundred times over. Lazy, very lazy.
Guest dangerousgte
I`ve found out that when mine was imported they just put an 110 mph face on, this reads correct the only prob is you`ve got to put it back to the 180 kph face then install the chip into the wiring on the back of the speedo cluster then it will read spot on in mph but u need a sticker (if u by the cheep nasty face) just to put over the kph writing on the face a garage quoted me 130 quid
