Nic Posted September 24, 2002 Share Posted September 24, 2002 I currently have a straight through ARC Titan exhaust system fitted and I want to change the rear silencer for something a little less restrictive and slightly louder. I was wondering if a different make of rear silencer will bolt onto the end of the ARC piping i.e is it a standard connection or will each brand of exhaust have it's own fitting? Does anyone have any photos of the connecting bracket on the rear of a Blitz Nurspec and HKS silencer they could send me please? cheers Quote Link to comment Share on other sites More sharing options...
Alex Posted September 24, 2002 Share Posted September 24, 2002 Nic, if ARC do a back box only version of the Titan then I would guess it is a standard fitting for the Supra...ie it would have to be able to connect to the stock exhaust. Can you confirm that? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 25, 2002 Author Share Posted September 25, 2002 Hi Alex ARC only do the full system. So are all the branded exhausts with a rear silencer only option compatible with the stock Toyota front exhaust section? The ARC piping is 80cm diameter, will I need to get a rear silencer that is also 80cm, or would a larger pipe fit eg. 90 or 95cm? The Blitz Nurspec has 80cm piping and can be bought as just the silencer, does anyone know if this will fit onto the OEM Toyota piping, if it does then I just need to check if the ARC bracket is the same. Any help would be appreciated, Cheers Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted September 26, 2002 Share Posted September 26, 2002 80cm diameter......Holy Cow!!!!!!! You running the sewage pipe version there Nic ???? Sorry can't help with your problem......but the thought of an 80cm diameter exhaust pipe........ Quote Link to comment Share on other sites More sharing options...
Nic Posted September 26, 2002 Author Share Posted September 26, 2002 mm.......... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 26, 2002 Share Posted September 26, 2002 Originally posted by Nic I currently have a straight through ARC Titan exhaust system fitted and I want to change the rear silencer for something a little less restrictive and slightly louder. I was wondering if a different make of rear silencer will bolt onto the end of the ARC piping i.e is it a standard connection or will each brand of exhaust have it's own fitting? Does anyone have any photos of the connecting bracket on the rear of a Blitz Nurspec and HKS silencer they could send me please? cheers Cat back system complete will be safer, i reckon the ARC may well use different flange style / size / position to other stuff. Haven't any pics and the 3 MKIV's here all have stock sytems. I am getting a new Super Dragar in later today or tomorrow hopefully can photo that, on and off a car if it helps. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 26, 2002 Author Share Posted September 26, 2002 Hi Chris That would be great if you could. cheers Quote Link to comment Share on other sites More sharing options...
