Paul372 Posted March 19, 2009 Share Posted March 19, 2009 what type of spray paint do i use to spray the plastic spark plug cover on the supra, i want to spray it gloss black, you can't use the normal stuff can you Quote Link to comment Share on other sites More sharing options...
patrikbrunt Posted March 19, 2009 Share Posted March 19, 2009 normal spray paint will be fine mate. I sprayed a metal spark plug cover on my old vaux with normal paint and it was fine, no problems with heat etc. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 19, 2009 Share Posted March 19, 2009 To spray paint plastic and get it to stick you need plastic primer. U-POL 20:03 is the name of the stuff I've used in the past, don't know if its available in an aerosol tho. Quote Link to comment Share on other sites More sharing options...
benkei Posted March 19, 2009 Share Posted March 19, 2009 What colours do the spark plug covers come in? Grey and blue? Quote Link to comment Share on other sites More sharing options...
merckx Posted March 19, 2009 Share Posted March 19, 2009 Halfords sell their own plastic primer in a spray can. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 19, 2009 Share Posted March 19, 2009 Halfords sell their own plastic primer in a spray can. And order is once again restored to the world:) Quote Link to comment Share on other sites More sharing options...
Scott Posted March 19, 2009 Share Posted March 19, 2009 I didn't bother with plastic primer, its over rated lol. I sprayed mine with the chrome paint off of ebay. I just gave it a quick rub and a clean then sprayed. I have a can of plastic primer but i really didn't like it. I used it the first time i refurbed a set of headlights, didn't bother the 2nd time. If you want gloss black, it might be better to use matt then lacquer? The reason i say that is matt is MUCH easier to spray from a can than gloss is. The lacquer does all the glossing for you. Just give it a rub down with a some high grit paper (i use 2000 but that might be overkill) after you have sprayed it matt, to flatten the paint, then lacquer! Quote Link to comment Share on other sites More sharing options...
Paul372 Posted March 20, 2009 Author Share Posted March 20, 2009 so they dont do spray paint for plastic just use the normal stuff, what about the heat from the engine will the paint still be ok from that Quote Link to comment Share on other sites More sharing options...
Scott Posted March 20, 2009 Share Posted March 20, 2009 Should be fine for the spark plug cover, i've never known anyone to use any special paints for that area. If you want to be extra safe you could buy VHT paint and VHT lacquer but i think that might be overkill. Saying that, if it costs the same you might as well. Quote Link to comment Share on other sites More sharing options...
Soaruss Posted March 20, 2009 Share Posted March 20, 2009 As has been said normal spray paint is fine for ANY plastic under the bonnet, heat wont effect it. If doing such as cam covers or any other engine bit, Plastikote spray paint is fine, its a higher temp paint, also from Halfords and the like. This was my MR2 engine done in Plastikote Quote Link to comment Share on other sites More sharing options...
