Robbie Posted March 19, 2009 Share Posted March 19, 2009 I pulled up at Morrisons to get some fuel for my car yesterday evening, switched of the ignition and lights and filled up the car. When I started up the car and switched on the lights once more... Nothing! In the end I drove home on the front fogs and sidelights. By the time I returned home it was too late to start fiddling with the lights. I tried again this morning before work but nothing! Which fuse does the lights? Could it be a bad earth? Could the bulbs have gone at the same time? Have the ballasts gone south! Has anyone else suffered the same problem with HID's? Quote Link to comment Share on other sites More sharing options...
R Black Posted March 19, 2009 Share Posted March 19, 2009 cant see both hids failing at the same time, and the last time a headlight failed on a car fot me iirc the fuses were for the left and the right side, so were independan, i dont know if our Supes are the same in that respect tho. Good luck. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 19, 2009 Share Posted March 19, 2009 The fuse is labelled in the fuse box on the right hand side of the engine bay, there is a 15A fuse for each headlight driving light, I would start there Quote Link to comment Share on other sites More sharing options...
Robbie Posted March 19, 2009 Author Share Posted March 19, 2009 Two 15Amp fuses. Ok Great! I'll have a look later. I' doubt both the bulbs or ballasts blew at the same time but you never know. Matt Harwood wired them up for me so I have to admit to not really taking much notice of the installation, just happy that I could see the road so much more clearly at night. ( not including last night:Pling:) They've been on the car for a couple of years now without issue, although last week, now I think on it they went out last week briefly after they had been on for a while when I turned them back on to put the car away, Hmmm! Quote Link to comment Share on other sites More sharing options...
mplavery Posted March 19, 2009 Share Posted March 19, 2009 Two 15Amp fuses. Ok Great! I'll have a look later. I' doubt both the bulbs or ballasts blew at the same time but you never know. Matt Harwood wired them up for me so I have to admit to not really taking much notice of the installation, just happy that I could see the road so much more clearly at night. ( not including last night:Pling:) They've been on the car for a couple of years now without issue, although last week, now I think on it they went out last week briefly after they had been on for a while when I turned them back on to put the car away, Hmmm! On mine you have 15amp fuse on the Ballasts as well which you might wanna check. I had to replace both my ballasts pack, one blew then 2 mths later the other one went lol got them from Whifbitz Quote Link to comment Share on other sites More sharing options...
Robbie Posted March 19, 2009 Author Share Posted March 19, 2009 What kind of voltage should you be seeing when measuring from the ballast to the bulb? Quote Link to comment Share on other sites More sharing options...
heckler Posted March 19, 2009 Share Posted March 19, 2009 What kind of voltage should you be seeing when measuring from the ballast to the bulb? erm.. at the last check, about 25KV Quote Link to comment Share on other sites More sharing options...
Robbie Posted March 19, 2009 Author Share Posted March 19, 2009 erm.. at the last check, about 25KV 25000 volts:Pling: Ok! I doubt my volt B&Q volt meter will read that! I was going to check to see how far along the circuit the power went if at all with my volt meter. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted March 19, 2009 Share Posted March 19, 2009 (edited) yeah dont put a volt meter across the bulb output. the intitial fire up voltage from the ballasts are in the region of 25KV edit - just checked and the majority of mid range multimeters have a surge protection of 6KV which is nice to know Edited March 19, 2009 by T2 MSW (see edit history) Quote Link to comment Share on other sites More sharing options...
heckler Posted March 19, 2009 Share Posted March 19, 2009 25000 volts:Pling: Ok! I doubt my volt B&Q volt meter will read that! I was going to check to see how far along the circuit the power went if at all with my volt meter. yup, think your B&Q volt meter might struggle a bit Quote Link to comment Share on other sites More sharing options...
Robbie Posted March 19, 2009 Author Share Posted March 19, 2009 Just in case I end up needing a new set of hids (4300) , who/where is it best to speak/go to? Quote Link to comment Share on other sites More sharing options...
johnny g Posted March 19, 2009 Share Posted March 19, 2009 I got mine from Nic (Import Pimp) and I'm very happy with them. Great vision. But, people here also report good things from Knight Racer (http://www.justhid.co.uk) Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted March 19, 2009 Share Posted March 19, 2009 Yeh ive got KR ones, and they are great. Quote Link to comment Share on other sites More sharing options...
lui Posted March 19, 2009 Share Posted March 19, 2009 Just in case I end up needing a new set of hids (4300) , who/where is it best to speak/go to? Knightracer were also doing some good deals on them too Quote Link to comment Share on other sites More sharing options...
SteveR Posted March 19, 2009 Share Posted March 19, 2009 Your car is just too fast Robbie, the light has trouble keeping up. Quote Link to comment Share on other sites More sharing options...
CarlT67 Posted March 19, 2009 Share Posted March 19, 2009 Your car is just too fast Robbie, the light has trouble keeping up. Tis probably the problem though. Quote Link to comment Share on other sites More sharing options...
Konrad Posted March 19, 2009 Share Posted March 19, 2009 It is possible that you current installation is struggling to fire up ballast at initial stage. To do it properly you will need harness, so power will be drained straight from the battery on start, not through all internal light system, fuses and such. I got mine from HERE,worked very well Quote Link to comment Share on other sites More sharing options...
Robbie Posted March 20, 2009 Author Share Posted March 20, 2009 Your car is just too fast Robbie, the light has trouble keeping up. E85 can do that to a car:D:cool: The sad truth is that the only things that have trouble keeping up with my car are my bank balance and my reactions! Re lights; I'll check the connections today at some point. Quote Link to comment Share on other sites More sharing options...
Robbie Posted March 20, 2009 Author Share Posted March 20, 2009 I got the volt meter out. I had to remove the headlamps to get to the wires and ballasts. When I checked the voltage across the wires I was only getting 2.3volts. when I removed the passenger headlamp I could see the wireing. It turned out to be a separate fuse attatched to the wire harness had gotten corroded. The HIDs had been wired up with a harness simialr to the one shown in the thread on ebay. I cleaned up all the connections and ta da...all lights were blazing away again. Thanks for the help and advice. Rob Quote Link to comment Share on other sites More sharing options...
