Can you see 2nd turbo turbine if de-cat is removed?
Scott
I would have thought so, although whats the reasoning behind it? you would soon know if you had a problem without looking
Asked loads of questions in the one thread but got very little response so i thought a direct question would work better lol.
Basically i get no boost from the 2nd turbo. If i do the 5 min TTC mod i get no boost from either turbo, if i do the permanant TTC mod i get no boost from either turbo. This lead me to believe tubby 2 was fooked and that the boost generated from turbo 1 was being let out via the 2nd turbo's cold side rather than being put into the engine.
Everything i have tried points to a fooked 2nd turbo so i was wondering if there was an easy way of physically checking without removing the assembly.
Cheers
Cheers
And you have throughly checked every pipe for tiny splits/tears and all vsv's etc?
i took the vac pipes and vsv pipes out of the equation by hard wiring the turbo's into ttc. Even without any vsv's the turbo's should still fire up. I replaced all the vac hoses, turbo pipes and refitted the intercooler. I have to assume now its the 2nd turbo.
