Testing O2 Sensors ???
lui
Just found this post is this they way to test them ??? & at £125 for new sensor don't want to splash out if old one is fine
This should be in technical section.
To test the sensor, start the engine and let it warm up
Bridge out terminals TE1 and E1 on the diagnostics port
Connect a multimeter (non digital is best) between the VF1 and E1 terminals of the diagnostics port.
With the engine held at 2000rpms the Multimeter should fluctuate back and forth more than 8 times in 10 secs
Any slower and the sensor needs replaced.
Main link to above below:
http://www.mkivsupra.net/vbb/showthread.php?t=171963&highlight=sensor
Edited by lui (see edit history)
