Fields harness and extra wiring
ADL Mark
Just finished doing some bits to my fields harness and adding some extra wires to it to make it useful.
I've made a small loom and wired it in to the harness for my datalogger (Innovate LMA-3). This loom has it's own plug so that the datalogged can be unplugged from the harness and either removed without too much hassle with pulling wires back through small gaps in the dashboard. I've also got a few spare wires in the harness should I want to expand what I do with the datalogger or add extra functionality.
One last thing that I had a brainwave about the other day, was finding a fairly simple way to power my gadgets and accessories. Things like gauges, boost controller, etc. I wanted a way to easily share one power source amongst these devices and them not be permanently wired in.
The idea I came up with was using Molex connectors, the same as the connectors used in computers to connect hard drives and CD/DVD drives. My main reasonings being that the connectors are cheap and easy to come by, and that you can plug and unplug things very easily so they are not hard wired in. Everything becomes modular as such. You can even expand the amount of connectors easily by going down the local computer shop and buying splitters to add 2 or 3 more connectors.
So I've now got this:
http://www.i-macca.co.uk/stuff/supe/supe-fields1.jpg
http://www.i-macca.co.uk/stuff/supe/supe-fields2.jpg
You can see the two connectors I've added, the large 8-pin for the data logger harness and the smaller 4-pin for the power. I've only bothered using two of the four pins for 12V and earth as that's all I will be needing.
This shows one of the 3-1 splitters for the Molex power connectors:
http://www.i-macca.co.uk/stuff/supe/supe-fields3.jpg
And plugged in to the harness connector:
http://www.i-macca.co.uk/stuff/supe/supe-fields4.jpg
And then with the boost controller and a couple of temperature sensors plugged in for power. The reason for the extra Molex plugs in the temperature sensors is that they are originally designed for computer case use, and there is (hidden by the black tape) and inline resistor for them. I could have taken out one of the plugs, but I hadn't thought about it at the time and I can't be bothered now:
http://www.i-macca.co.uk/stuff/supe/supe-fields5.jpg
Cheers Darryl :)
I'm very glad I bought it, the one and only thing that I wired in to the car loom was the BCC and it was a nightmare, there's so little slack in the loom that it made it very difficult to do anything.
It's a godsend having this on the desk and being able to fit everything you want then put it in the car!
