interesting... "800" hp @ 2800rpm
Guigsy
http://www.boostlogic.com/xcart/product.php?productid=160&cat=9&page=1
This new revolutionary turbo kit will finally meet the goals of every turbocharger enthusiast. While compound turbocharging is usually used on diesel applications, we have devised a method for this kit to work on a gasoline powered engine. Unparalleled low and midrange torque coupled with high horsepower. There’s no need for nitrous as this kit spools up as if it’s always on nitrous. The compound turbocharger kit builds 20psi at 2800 rpms while flowing enough air to make 800+ RWHP!
I dont know much about Single turbo's but that sounds interesting. anyone know of any running?
http://www.boostlogic.com/pics/supratt/compound/blcompoundstand1.jpg
Surely if you drive the second turbo out the back of the first turbo, you'll lose loads of heat, and therefore gas volume to drive the second blower. Also as previously suggested, pushing boosted air into the inlet of the smaller turbo would surely over-speed the compressor wheel. Cue many replacement turbos...Nice idea, but I just don't see it working.
Hmmm, looks interesting enough..
Surely the smaller 2nd turbo is going to be a restriction or as others have said, it is going to spin like a like a really fast spinning thing. I would have assumed it also has a slightly smaller exhaust manifold header which would create a very interesting flow pattern in the manifold never mind heat spots, but doesn't seem to be the case.
Anybody notice that they have been doing initial trails on an NA :)
http://www.boostlogic.com/pics/supratt/compound/blcompoundstand2.jpg
Edited by JustGav (see edit history)
Compund charging works and works well, its getting big in deisel tuning world, and also some of the big companies like Cummins have production systems in the market.
This was already tried on the Supra a few years ago, though i cant find the link...dont think it went to plan,, And i think Arnout's Compounded Supercharger/turbo charger setup never got finished either??
Edited by bondango (see edit history)
Compound charging has been around for ages. Some Aero engines during world war 2 used a super charger and a turbo together, and would go many, many thousands of miles reliably. There's bound to be alot of heat in the engine bay though.
Of all the big turbo kit suppliers, boostlogic seem to be one of the better ones, and i'm sure they wouldn't risk putting this on the market without fully testing the setup.
