colsoop Posted March 16, 2009 Share Posted March 16, 2009 Nice one Wez. Are you planning to strip more weight out of it ? Link to comment Share on other sites More sharing options...
Wez Posted March 16, 2009 Author Share Posted March 16, 2009 colsoop said: Are you planning to strip more weight out of it ? Yes I already have lexan rear and sides to go on and the doors and rear hatch are going to get the same treatment as Ryans. I also have some 17" gram light wheels to go on. All the excess wiring still needs removing, I am not sure what else can come out really. Link to comment Share on other sites More sharing options...
MarkR Posted March 16, 2009 Share Posted March 16, 2009 Looking good. What does the 8 position calibration switch for the ECU control do? Link to comment Share on other sites More sharing options...
Wez Posted March 16, 2009 Author Share Posted March 16, 2009 TyranoSupraRex said: Looking good. What does the 8 position calibration switch for the ECU control do? Lots of things which are all configurable. * Fuel map selection (4) * Ignition map selestion (4) * Boost level * knock control * Rev limit * Pit limit * Traction control level The list goes on and on Link to comment Share on other sites More sharing options...
j_jza80 Posted March 16, 2009 Share Posted March 16, 2009 Great work with the dash, it looks like a cockpit from a Spitfire or similar How easy did you find it working with carbon sheet for the dash? Link to comment Share on other sites More sharing options...
Wez Posted March 16, 2009 Author Share Posted March 16, 2009 j_jza80 said: Great work with the dash, it looks like a cockpit from a Spitfire or similar How easy did you find it working with carbon sheet for the dash? Its not too bad, if you dont mask it up it does fray and break up. Link to comment Share on other sites More sharing options...
colsoop Posted March 16, 2009 Share Posted March 16, 2009 Wez said: Yes I already have lexan rear and sides to go on and the doors and rear hatch are going to get the same treatment as Ryans. I also have some 17" gram light wheels to go on. All the excess wiring still needs removing, I am not sure what else can come out really. Im sure you'll find some more bits and bobs Link to comment Share on other sites More sharing options...
Pig Posted March 16, 2009 Share Posted March 16, 2009 Look great wez, would you please consider re-labeling the switches as i feel they look terrible on the wonk like that. Please, im begging you. Jon Link to comment Share on other sites More sharing options...
bignum Posted March 16, 2009 Share Posted March 16, 2009 Pig said: Look great wez, would you please consider re-labeling the switches as i feel they look terrible on the wonk like that. Please, im begging you. Jon Fussy bugger, i thought the same, Link to comment Share on other sites More sharing options...
Wez Posted March 16, 2009 Author Share Posted March 16, 2009 Would only take a minute to redo the labels, I will have another crack at them this week Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2009 Author Share Posted March 18, 2009 Not very exciting but the new rear exhaust mount has turned up, hopefully this will solve my exhausts position issues. When I installed the Veilside Ti many moons ago I completely forgot that I removed the stock mount as the Ti came with its own mounts. Link to comment Share on other sites More sharing options...
jevansio Posted March 18, 2009 Share Posted March 18, 2009 Hardcore setup Wez Did you ever get a side mount seat setup sorted? Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2009 Author Share Posted March 18, 2009 New Cam Covers and Breather Setup My current breather setup is functional but not ideal Today I picked up my new cam covers, a big thanks to Steve at Autotec, the finish on these is lovely, I decided to go with black fittings over the normal blue and red Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2009 Author Share Posted March 18, 2009 jevansio said: Hardcore setup Wez Did you ever get a side mount seat setup sorted? Subframes on order, should be here the end of the week hopefully. Link to comment Share on other sites More sharing options...
jevansio Posted March 18, 2009 Share Posted March 18, 2009 Wez said: Subframes on order, should be here the end of the week hopefully. Does it retain the slide functionality, is it 3 seperate parts (frame, sliders & side mounts) or one complete unit, do you know the weight of each? Sorry for all the questions Link to comment Share on other sites More sharing options...
Ryan.G Posted March 18, 2009 Share Posted March 18, 2009 Going to look awesome mate! Dont forget the masking tape trick when you redo your switch labels Link to comment Share on other sites More sharing options...
DannoSupra Posted March 18, 2009 Share Posted March 18, 2009 Nice Cam Cover's!!!! Looks good in Black with the Black Breather fittings Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2009 Author Share Posted March 18, 2009 jevansio said: Does it retain the slide functionality, is it 3 seperate parts (frame, sliders & side mounts) or one complete unit, do you know the weight of each? Sorry for all the questions I cannot answer any of your questions yet, I will try when they arrive Link to comment Share on other sites More sharing options...
jevansio Posted March 18, 2009 Share Posted March 18, 2009 Wez said: I cannot answer any of your questions yet, I will try when they arrive cheers Link to comment Share on other sites More sharing options...
Kev.O Posted March 18, 2009 Share Posted March 18, 2009 DannoSupra said: Nice Cam Cover's!!!! Looks good in Black with the Black Breather fittings Probably the best I've seen Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2009 Author Share Posted March 18, 2009 Ryan.G said: Dont forget the masking tape trick when you redo your switch labels Top tip matey, I wondered how people got there labels straight Link to comment Share on other sites More sharing options...
j_jza80 Posted March 18, 2009 Share Posted March 18, 2009 Kev.O said: Probably the best I've seen Link to comment Share on other sites More sharing options...
TLicense Posted March 18, 2009 Share Posted March 18, 2009 Kev.O said: Probably the best I've seen *ahem* http://img.photobucket.com/albums/v649/tlicense/Blitz%20Twin%20Insallation/121_2146Large.jpg Looking good there buddy. How long till the first event now? Link to comment Share on other sites More sharing options...
Kev.O Posted March 18, 2009 Share Posted March 18, 2009 TLicense said: *ahem* http://img.photobucket.com/albums/v649/tlicense/Blitz%20Twin%20Insallation/121_2146Large.jpg Looking good there buddy. How long till the first event now? I was including the matching sparkplug cover Link to comment Share on other sites More sharing options...
Wez Posted March 23, 2009 Author Share Posted March 23, 2009 No real updates from me this weekend as I was out all day Sat on an Aerial Atom experience, then Sunday was spent in the garden fitting some new lights. I have managed to pick and order some more bits though :- * buttons for dash2, need fitting to my custom dash * bride subframe for drivers seat * new water outlet ready for modding to remove stock water outlets * ordered new catch tank from whiffin, same as JamiePs Link to comment Share on other sites More sharing options...
