Wez Track Supra
Wez
  • Replies 378
Posted Images
If you line up the two pimk arrows you get as much negative camber as the adjusters will allow, so can get quite a lot more.
Sounds good although I am guessing its not quite a simple as just adjusting that front adjuster.
Roughly how much negative I am running at the moment and what can it go too?
Looks about 1.5 to 2 degrees, I'd try 3.5 and see what happens. Hard to be sure off a photo though. You could work it out with trigonometry if you were a sadist.
Should front and rear be the same?
Yes, you should be able to get some more negative, at the expense of some positive castor, which will limit the camber gain in steer. Vicious circle. You ideally need different arms for track work. You can get rid of the bush compliance as well, then, which will make a hell of a difference to the feel of the car under duress.
  • 3 weeks later...
I am getting a complete set of 2nd hand arms from Paul, I will use these as a basis for either some modified or complete custom units.
Cheers. Where does this mount and what does the cable connect to? I see you can get some quite long cable extensions which is why I was wondering where you'd use such long lengths.
It connects to the steering rack, not looked for a mounting spot yet.
  • 1 month later...
Been a while since I updated this thread but some more bits arrived this week so here are some pics :D
I am undecided if I should use the -8 o-ring to -6an rail adapters and use -6 lines are just get some -8 adapters and do the feeds in -8. At the moment I have -6an dual feed and -6an return, my bosch fuel reg is -6an in and out.
With my Bosch 044 pump I am planning to run 55psi static would should give me approx 1000cc :thumbs:
New Injectors and Rail
