Wez Track Supra
Wez
  • Replies 378
Posted Images
Are you planning to strip more weight out of it ?
Yes ;)
I already have lexan rear and sides to go on and the doors and rear hatch are going to get the same treatment as Ryans. I also have some 17" gram light wheels to go on.
All the excess wiring still needs removing, I am not sure what else can come out really.
Looking good. What does the 8 position calibration switch for the ECU control do?
Lots of things which are all configurable.
* Fuel map selection (4)
* Ignition map selestion (4)
* Boost level
* knock control
* Rev limit
* Pit limit
* Traction control level
The list goes on and on :D
Great work with the dash, it looks like a cockpit from a Spitfire or similar :D
How easy did you find it working with carbon sheet for the dash?
:lol:
Its not too bad, if you dont mask it up it does fray and break up.
Yes ;)
Im sure you'll find some more bits and bobs :D
Not very exciting but the new rear exhaust mount has turned up, hopefully this will solve my exhausts position issues. When I installed the Veilside Ti many moons ago I completely forgot that I removed the stock mount as the Ti came with its own mounts.
New Cam Covers and Breather Setup
My current breather setup is functional but not ideal :D
Today I picked up my new cam covers, a big thanks to Steve at Autotec, the finish on these is lovely, I decided to go with black fittings over the normal blue and red :thumbs:
Does it retain the slide functionality, is it 3 seperate parts (frame, sliders & side mounts) or one complete unit, do you know the weight of each? Sorry for all the questions :D
:lol:
I cannot answer any of your questions yet, I will try when they arrive :innocent:
No real updates from me this weekend as I was out all day Sat on an Aerial Atom experience, then Sunday was spent in the garden fitting some new lights.
I have managed to pick and order some more bits though :-
* buttons for dash2, need fitting to my custom dash
* bride subframe for drivers seat
* new water outlet ready for modding to remove stock water outlets
* ordered new catch tank from whiffin, same as JamiePs
