nige Posted March 15, 2009 Share Posted March 15, 2009 A fellow supra owner rewired my fuel pump the wires are in the rear quarter on the left side of the boot basically what it does is run the pump at 12v at all times instead of 9v and I think i'am correct in saying 12v when revs are higher,the pump is a walbro upgrade bought from whiffbits as the car is BPU,recently the pump buzzes quite loudly could this indicate its about to fail and doing this rewiring mod is it a bad thing?Any advice most appreciated guys,cheers, Nige. Quote Link to comment Share on other sites More sharing options...
paul mac Posted March 15, 2009 Share Posted March 15, 2009 do a search on this mate, it was urban myth a few years back that the 12 volt mod was a good thing, it has been pretty much prooved its a waste of time and can be potentially dangerous Quote Link to comment Share on other sites More sharing options...
nige Posted March 15, 2009 Author Share Posted March 15, 2009 Thanks for that,I done a search and think I will be reverting back to the way it is supposed to be,sounds dangerous,cheers. Quote Link to comment Share on other sites More sharing options...
Homer Posted March 15, 2009 Share Posted March 15, 2009 Good decision They work absolutely fine with the stock setup, even with a single. Quote Link to comment Share on other sites More sharing options...
Bossco Posted March 15, 2009 Share Posted March 15, 2009 I think the buzzing sound is quite common. You can hear mine on tick over and all seems to be well. Quote Link to comment Share on other sites More sharing options...
nige Posted March 15, 2009 Author Share Posted March 15, 2009 Just spoke to my mate and his reasoning is that BPU spec if your running higher boost theres a potential lean spot when the pump changes from 9v to 12v can this cause damage? Quote Link to comment Share on other sites More sharing options...
paul mac Posted March 15, 2009 Share Posted March 15, 2009 Just spoke to my mate and his reasoning is that BPU spec if your running higher boost theres a potential lean spot when the pump changes from 9v to 12v can this cause damage? yes that was what was said back in the day and without offending your mate its nonsense, i run 500hp on a walbro running stock Toyota wiring and also ran BPU for 2 and a half years, i did try the mod it made absolutely no difference (except more noise) Quote Link to comment Share on other sites More sharing options...
Homer Posted March 15, 2009 Share Posted March 15, 2009 As Paul has said, it's completely unnecessary. Using the stock setup is very, very tried and tested, it works absolutely fine. Quote Link to comment Share on other sites More sharing options...
nige Posted March 15, 2009 Author Share Posted March 15, 2009 Cheers guys gonna change back before the next outing. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 16, 2009 Share Posted March 16, 2009 All you are doing is heating the fuel up and wasting fuel pump life. Quote Link to comment Share on other sites More sharing options...
