marbleapple Posted March 14, 2009 Share Posted March 14, 2009 Hi All, In the process of replacing my standard wheel for a momo one. I have the correct boss but i have two questions: 1. The cable that came with the boss only has one connector when the wheel has fitting bits for 2.... should I have two wires? (see pics) 2. The boss has a metal ring which seems to fit on the top but it sticks out and prevents the bolts on the wheel connecting with the boss.... should I just not put it on or is it included for a reason? Thanks guys Quote Link to comment Share on other sites More sharing options...
suprasurrey Posted March 15, 2009 Share Posted March 15, 2009 If you look at the top connector in the first photo you can see an earth symbol. I would run a wire from there to the metal part of the boss somehow. As for the second photo, I`d say that the ring is just an adaptor for different sizes / makes of wheel. Quote Link to comment Share on other sites More sharing options...
Soaruss Posted March 15, 2009 Share Posted March 15, 2009 Where did you get the boss from and how much?? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 15, 2009 Share Posted March 15, 2009 Yes all you do is connect one wire to the horn and the other to and earth, as all the button does is complete the circuit to earth. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted March 15, 2009 Author Share Posted March 15, 2009 Where did you get the boss from and how much?? £50 from Envy. One of the few things they have done right. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted March 15, 2009 Author Share Posted March 15, 2009 If you look at the top connector in the first photo you can see an earth symbol. I would run a wire from there to the metal part of the boss somehow. As for the second photo, I`d say that the ring is just an adaptor for different sizes / makes of wheel. Yes all you do is connect one wire to the horn and the other to and earth, as all the button does is complete the circuit to earth. Cheers guys thanks for the explaination. Never even noticed the earth symbol! - simple when you know Quote Link to comment Share on other sites More sharing options...
