chico Posted March 13, 2009 Author Share Posted March 13, 2009 the aristo TT ecu has 2jz-gt written on it, just to confirm The vvti Supra ecu to... couse my mate just pulled this out the one that i uploaded! BUT it has 6connections, (5small white+1big grey) Quote Link to comment Share on other sites More sharing options...
chico Posted March 13, 2009 Author Share Posted March 13, 2009 So what does your car actually have installed? A picture will tell all. In the non-VVTi the trac is a seperate ECU, that much is for certain. On some model VVTi's, it *might* be integrated (this is an assumption based on your picture). Dont have any pics of it until tomorrow, my mechanic have to take some... Quote Link to comment Share on other sites More sharing options...
chico Posted March 13, 2009 Author Share Posted March 13, 2009 the aristo TT ecu has 2jz-gt written on it, just to confirm how many connections does the aristo TT ecu have?? Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 13, 2009 Share Posted March 13, 2009 The issue is that the car runs for 3sec and dies. i´ve checked the fuelpump, and its running as its should! everything is working fine, like lights, wipers, etc etc... coz of that last connection hanging loose from the wiringloom! Is there an alarm on wiring loom or something like? Does the fuel pump run continuously, I've seen a VVTi that when the 12v mod was removed had issues exactly like that, ran for a few seconds and then stop, almost like the FPC signal to the ECU was wrong. Quote Link to comment Share on other sites More sharing options...
Robert Posted March 13, 2009 Share Posted March 13, 2009 god knows LOL, but i will see if i can find out. My stock ECU went along time ago. Do you know if the replacement VVTI engine was out of an aristo or a supra? I do know if you use a Supra ECU in a Aristo somethings don't work properly, but the other way around i don't know. Quote Link to comment Share on other sites More sharing options...
chico Posted March 13, 2009 Author Share Posted March 13, 2009 Is there an alarm on wiring loom or something like? Does the fuel pump run continuously, I've seen a VVTi that when the 12v mod was removed had issues exactly like that, ran for a few seconds and then stop, almost like the FPC signal to the ECU was wrong. it had a imobiliser but my mechanic took it out... by the book! he did a mod by connecting a 12v batt direct to the pump and still the same problem! 3sec and dies... Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 13, 2009 Share Posted March 13, 2009 it had a imobiliser but my mechanic took it out... by the book! he did a mod by connecting a 12v batt direct to the pump and still the same problem! 3sec and dies... Have you tried pulling the error codes? Quote Link to comment Share on other sites More sharing options...
chico Posted March 13, 2009 Author Share Posted March 13, 2009 god knows LOL, but i will see if i can find out. My stock ECU went along time ago. Do you know if the replacement VVTI engine was out of an aristo or a supra? I do know if you use a Supra ECU in a Aristo somethings don't work properly, but the other way around i don't know. What i´ve been told by Steve/Jezz it came out of a supra vvti 2000. Quote Link to comment Share on other sites More sharing options...
chico Posted March 13, 2009 Author Share Posted March 13, 2009 Have you tried pulling the error codes? NO error codes... thats why im so confused! Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 13, 2009 Share Posted March 13, 2009 it had a imobiliser but my mechanic took it out... by the book! he did a mod by connecting a 12v batt direct to the pump and still the same problem! 3sec and dies... Yes, but did you disconnect the FPC while you did this? Quote Link to comment Share on other sites More sharing options...
chico Posted March 13, 2009 Author Share Posted March 13, 2009 Yes, but did you disconnect the FPC while you did this? Yep Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 13, 2009 Share Posted March 13, 2009 Yep If the FPC was fully disconnected, and there is no alarm, then I'm out of ideas...sorry. It does sound VERY much like there might a wiring issue somewhere. Quote Link to comment Share on other sites More sharing options...
chico Posted March 14, 2009 Author Share Posted March 14, 2009 If the FPC was fully disconnected, and there is no alarm, then I'm out of ideas...sorry. It does sound VERY much like there might a wiring issue somewhere. No worries, thats why im looking for a pic off any other ecu that could be fitted in a supra. so i have a ecu with 5 small white connections and it says 2jz-gt. (but the big grey is missing). i´ll take some pics tomorrow and upload them! Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 14, 2009 Share Posted March 14, 2009 No worries, thats why im looking for a pic off any other ecu that could be fitted in a supra. so i have a ecu with 5 small white connections and it says 2jz-gt. (but the big grey is missing). i´ll take some pics tomorrow and upload them! Manual or auto? Just suddenly dawned on me... Quote Link to comment Share on other sites More sharing options...
chico Posted March 14, 2009 Author Share Posted March 14, 2009 manual 6speed v.161 Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 14, 2009 Share Posted March 14, 2009 (edited) Okay, I've just had a look and I think I've found the cable on the wiring diagram, just need to trace it, I believe it is labelled as connector H. Edited March 14, 2009 by JustGav (see edit history) Quote Link to comment Share on other sites More sharing options...
chico Posted March 14, 2009 Author Share Posted March 14, 2009 Okay, I've just had a look and I think I've found the cable on the wiring diagram, just need to trace it, I believe it is labelled as connector H. but what is it for?? Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 14, 2009 Share Posted March 14, 2009 (edited) If I am reading it correctly, there are 5 active pins on it... Black-Orange Yellow-Red Yellow White Yellow-Black They are all labelled as inputs, the blanks I'm not sure on yet, need to check other diagrams.. This is only right if it is the correct connector (H) They are labelled IND and CIND, not sure what that means yet. Edited March 14, 2009 by JustGav (see edit history) Quote Link to comment Share on other sites More sharing options...
chico Posted March 14, 2009 Author Share Posted March 14, 2009 ok Quote Link to comment Share on other sites More sharing options...
chico Posted March 14, 2009 Author Share Posted March 14, 2009 pins=connections?? Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 14, 2009 Share Posted March 14, 2009 pins=connections?? Yes Quote Link to comment Share on other sites More sharing options...
chico Posted March 14, 2009 Author Share Posted March 14, 2009 but what is the 6th pin for?? (the big grey one) Quote Link to comment Share on other sites More sharing options...
Homer Posted March 14, 2009 Share Posted March 14, 2009 Was it running okay when it left their place? If so what has happened in the mean time? was it driven to your place and if so, what changes have been made since? Any detail isn't too small to worth mentioning here. Quote Link to comment Share on other sites More sharing options...
chico Posted March 14, 2009 Author Share Posted March 14, 2009 Was it running okay when it left their place? If so what has happened in the mean time? was it driven to your place and if so, what changes have been made since? Any detail isn't too small to worth mentioning here. i brought it back on a flatbed. bought it as a non running. Quote Link to comment Share on other sites More sharing options...
Homer Posted March 14, 2009 Share Posted March 14, 2009 i brought it back on a flatbed. bought it as a non running. Thanks for clearing that up. I'll duck out of this now, but keep talking to Gav, he's one of the very few people who've done this swap before so has some real first-hand experience. Quote Link to comment Share on other sites More sharing options...
