picture of N/a Ecu
chico
  • Replies 72
Posted Images
but mine has 5connections and says 2jz-gt
but ive been told that tt has 3connections 2jz-gt
na has 3 connections 2jz-ge
vvti has 5small and 1big greyconnections 2jz-gt
im confused :confused:
If you have the above ECU then I'd defintely assume it is the VVTI or at least the 16bit ECU, can chance you can snap a picture of the engine bay?
The pic you posted is a VVTi manual ECU, that much is for sure.
Whether it's from an NA or TT is another matter, but I seriously doubt it's an NA one for the reason mentioned earlier.
Only thing I can think, is that it has had a lexus 2jz-gt put in, but I'm not sure how easy that would be do wiring wise once inside the car. I'd be pretty confident that it would be a bastid rewire job.
Thats what I'm thinking Gav, either that or an Aristo one.
Did your supra VVTi have the grey plug pictured?
ok, but i only uploaded pics of a REAL vvti ecu, thats not the one fitted...
the one fitted has only 5connections without the big grey to left in the pic!
so it looks like the one in pic but no big grey... so i´ve got a connection from the W.loom hanging loose! :(
so it looks like the one in pic but no big grey... so i´ve got a connections from the W.loom hanging loose! :(
Get a pic of the engine bay up chap, it will help no end, seriously.
dont have any pic of it yet...
The car was born SZ-R and been converted by Jezz/Steve to 90%, i bought it unfinished!
and Steve and jezz says its the right Ecu.
but i know for sure that the engine is a VVTI!
googled one and it looks like this!
I can't actually recall, busy looking on the net to see if I can find one... I did find the attached image on images.google.com which made me chuckle :)
If it has that engine, then it is a VVTi Twin Turbo and not an ECU and then you have the right ECU with the 5 connectors.
The pics should tell all, but in the mean time I think the extra plug at the bottom is an integrated trac control ECU. The plug is the right type for the seperate trac unit on the non-VVTi TT's.
Yes but Steve/Jezz told me that the wiringloom is from the same vvti engine... :confused:
The issue is that the car runs for 3sec and dies.
i´ve checked the fuelpump, and its running as its should!
everything is working fine, like lights, wipers, etc etc...
coz of that last connection hanging loose from the wiringloom!
my mate told me that the vvti only has one ecu for al... like throtthle, traction etc etc..
So what does your car actually have installed? A picture will tell all.
In the non-VVTi the trac is a seperate ECU, that much is for certain. On some model VVTi's, it *might* be integrated (this is an assumption based on your picture).
