brake or clutch leak
Guest david
Guest david
got a funny leak it ether brake or clutch fluid dripping from the bottom of the bell housing :( but brakes and clutch pedal seem OK the clutch is slipping a bit but has been slipping for the last few weeks and no leaks.and the reservoir not gone down any ideas
I suppose the clutch slave cylinder could leak through the shaft seal and run down inside the bellhousing. If you take the inspection cover off the passenger side you might be able to see, otherwise the slave cylinder is held on by two bolts - if you unbolt it you can pull it out and have a look and see if you can see anything.
