barneybrendan Posted March 12, 2009 Share Posted March 12, 2009 im now at my wits end.the problem has been going on for a month now. had to relocate the resevoir on my na.the car got started and drained the system.ive had the pump tapped out to take a fitting which is air tight,and no other visible leaks. basicly the fluid is just constantly frothing out the resevoir,and pump is making a racket as if its out of fluid. HELP PLEASE. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted March 12, 2009 Author Share Posted March 12, 2009 what fluid is recomended for the na.might be down to that as i have been using atf from work for plant machinery. Quote Link to comment Share on other sites More sharing options...
Bender Posted March 12, 2009 Share Posted March 12, 2009 Automatic transmission fluid Dexron-III Quote Link to comment Share on other sites More sharing options...
Rob Posted March 13, 2009 Share Posted March 13, 2009 im now at my wits end.the problem has been going on for a month now. had to relocate the resevoir on my na.the car got started and drained the system.ive had the pump tapped out to take a fitting which is air tight,and no other visible leaks. basicly the fluid is just constantly frothing out the resevoir,and pump is making a racket as if its out of fluid. HELP PLEASE. Just what the blue blazes are you doing? Where is this going? Quote Link to comment Share on other sites More sharing options...
