mike_mcevoy Posted March 12, 2009 Share Posted March 12, 2009 Does anyone know the cost of a standard FPR part number 23280-46030. I'm getting some strange fuelling issues when braking and everything else along the fuel line has been changed. Basically what I'm finding is occasionally when braking to a stop the fuelling goes off the scale lean on the AFR gauge and then stalls. It seems to be an intermittent fault when she is warm, unless anyone has an idea of what might cause this? cheers Mike Quote Link to comment Share on other sites More sharing options...
heckler Posted March 12, 2009 Share Posted March 12, 2009 Fuel pump? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 12, 2009 Share Posted March 12, 2009 First question, what type/make of AFR gauge? Did you know that on closed throttle the injector are not working, IE no fuel= lean AFRs 20.9. Quote Link to comment Share on other sites More sharing options...
mike_mcevoy Posted March 12, 2009 Author Share Posted March 12, 2009 its a two year old Walbro. Possible its gone faulty but I've never heard of that happening (not to say it doesnt)? Quote Link to comment Share on other sites More sharing options...
mike_mcevoy Posted March 12, 2009 Author Share Posted March 12, 2009 I'm running a AEM AFR gauge, it normally goes off the scale when letting of the accelerator but when coasting upto a stop its fairly steady at 14.9 or 15 unless it tries to stall when it goes off the scale. First question, what type/make of AFR gauge? Did you know that on closed throttle the injector are not working, IE no fuel= lean AFRs 20.9. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 12, 2009 Share Posted March 12, 2009 I'm running a AEM AFR gauge, it normally goes off the scale when letting of the accelerator but when coasting upto a stop its fairly steady at 14.9 or 15 unless it tries to stall when it goes off the scale. Sorry wasn't clear on that, thats on initial closed throttle and deceleration, once at idle it will be 14.7 ish:) Quote Link to comment Share on other sites More sharing options...
mike_mcevoy Posted March 12, 2009 Author Share Posted March 12, 2009 it's one of those PITA problems that has no clear issue standing out and becasue its intermittent you cant garranteee any one part causing it. think I'll just strip each component out in turn and check them. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted March 12, 2009 Share Posted March 12, 2009 I think I have a std FPR somewhere in the garage if you need it Quote Link to comment Share on other sites More sharing options...
kaahari Posted March 12, 2009 Share Posted March 12, 2009 Basically what I'm finding is occasionally when braking to a stop the fuelling goes off the scale lean on the AFR gauge and then stalls. It seems to be an intermittent fault when she is warm, unless anyone has an idea of what might cause this? cheers Mike I got samekind issues, i got stock fuelpump and it is happened couple of times last summer, cold and warm engine. Happens when coming to junction etc. ... is this normal? Quote Link to comment Share on other sites More sharing options...
mike_mcevoy Posted March 12, 2009 Author Share Posted March 12, 2009 I hope to god this isnt normal mine has only just started to do this in the last month or so. the only other thing that I was thinking was a faultly water temp sender screwing up the readings. I had this on a old Clio were it would constantly read cold so would have the choke on full all the time, but this seems to running in reverse? Quote Link to comment Share on other sites More sharing options...
Benjy Posted March 12, 2009 Share Posted March 12, 2009 (edited) Idle Speed Control Valve?? EDIT: My FPR on my NA was about £70 from Toyota. Edited March 12, 2009 by Benjy (see edit history) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 12, 2009 Share Posted March 12, 2009 I would also be inclined to reset the throttle switch/potentiometer;) Quote Link to comment Share on other sites More sharing options...
mike_mcevoy Posted March 12, 2009 Author Share Posted March 12, 2009 I've stripped and cleaned this but no difference. Idle Speed Control Valve?? EDIT: My FPR on my NA was about £70 from Toyota. Quote Link to comment Share on other sites More sharing options...
mike_mcevoy Posted March 24, 2009 Author Share Posted March 24, 2009 Sorted now, turns out it’s the old age problem of the coil pack connectors. What looks like what was happening was that when I was braking downhill especially, it exacerbated the issue where he first three clips weren’t being held in properly and they were backing off as I broke causing it to drop to at least 3 cylinders and then stalling out. £12ish fix from Paul at Whifbitz Quote Link to comment Share on other sites More sharing options...
