standard FPR
mike_mcevoy
Does anyone know the cost of a standard FPR part number 23280-46030. I'm getting some strange fuelling issues when braking and everything else along the fuel line has been changed.
Basically what I'm finding is occasionally when braking to a stop the fuelling goes off the scale lean on the AFR gauge and then stalls. It seems to be an intermittent fault when she is warm, unless anyone has an idea of what might cause this?
cheers
Mike
I'm running a AEM AFR gauge, it normally goes off the scale when letting of the accelerator but when coasting upto a stop its fairly steady at 14.9 or 15 unless it tries to stall when it goes off the scale.
First question, what type/make of AFR gauge?
Did you know that on closed throttle the injector are not working, IE no fuel= lean AFRs 20.9.
Sorry wasn't clear on that, thats on initial closed throttle and deceleration, once at idle it will be 14.7 ish:)
cheers
Mike
I got samekind issues, i got stock fuelpump and it is happened couple of times last summer, cold and warm engine. Happens when coming to junction etc. ... is this normal?
I hope to god this isnt normal :)
mine has only just started to do this in the last month or so. the only other thing that I was thinking was a faultly water temp sender screwing up the readings. I had this on a old Clio were it would constantly read cold so would have the choke on full all the time, but this seems to running in reverse?
  • 2 weeks later...
Sorted now, turns out it’s the old age problem of the coil pack connectors.
What looks like what was happening was that when I was braking downhill especially, it exacerbated the issue where he first three clips weren’t being held in properly and they were backing off as I broke causing it to drop to at least 3 cylinders and then stalling out.
£12ish fix from Paul at Whifbitz :)
