Trd holes in the front fender
Guest speeddy
I would make some up in cardboard then stick them on untill you get a size and shape your happy with then mark around the template, measure from the door and wing gap to the edge of the template top and bottom to make sure both straight edges are parallel to each other then measure down from the top of the wing to the staight edge to get both sides the same hight ;)
