fuel injector stuck open
absz
Right had my fuel injectors cleaned and flow tested all fine and within 1% off each other, i have now fitted the injectors back onto the car and one of them remains stuck open just filling the piston chamber with fuel :( is there something i can do with this injector or shall a just buy a new set.
ps injectors are 780cc delphi
Edited by absz (see edit history)
had it clicking with a feed and threw it across the garage a few times:d still can blow past it but with bit more force. thinking of buying a new set as this will always play in my mind even if fixed.
UPDATE
injector seemed all ok refitted back to rail and took pressure to 36psi no problems refitted pigtails and cranked over engine and the same injector stuck open AGAIN :( removed pigtail connector still stuck open. looks like its for the bin.
