j1mb0b1 Posted March 10, 2009 Share Posted March 10, 2009 I have done a search but not found anything about this, I have a kph speedo that has been converted into mph so the dial moves slower and displays mph but I have a new set of dials that are mph how would I go about setting this up ? Thanks j... Quote Link to comment Share on other sites More sharing options...
SteveR Posted March 10, 2009 Share Posted March 10, 2009 If the numbers are in the same position (and they should be) as the needle sweeps through the dial then you don't need to do anything. If they aren't, then you will have to see what convertor you have fitted and IF it has an adjustment factor. Quote Link to comment Share on other sites More sharing options...
j1mb0b1 Posted March 10, 2009 Author Share Posted March 10, 2009 Hi steve, I dont think they will be as 100mph atm is shown around the 60mph mark on the dial i have how do i no if i have a converter and where will it be located thanks Jamie.. Quote Link to comment Share on other sites More sharing options...
