eyefi Posted September 22, 2002 Share Posted September 22, 2002 is there anything on the stock 6 speed worth upgrading, clutch, shifter, anything? it will b handling 400 - 450 flyhp, assume bits need replacing anyway. ta Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted September 23, 2002 Share Posted September 23, 2002 The stock setup (box & clutch) should be able to handle that sort of power just fine. You may want to consider a mildly uprated clutch, like an RPS Stage 2, if and when your current clutch does give up the ghost. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 23, 2002 Share Posted September 23, 2002 I went through a standard Toyota clutch in less than 20,000km, running 1.2bar, a lot of this was was city driving though. I've just had a TRD twin plate clutch fitted which initially felt heavy and was very on/off. As I've done a few miles with it I have got used to the feel and you can really feel it handle the power well. One thing you will notice with an uprated clutch and lightened flywheel is that it sounds very rattly at ticking over, oh and hill starts can be fun:eek: Quote Link to comment Share on other sites More sharing options...
randy Posted September 23, 2002 Share Posted September 23, 2002 Yeah Mate! Clutch is a good upgrade also a C's short shifter if you want really short throws. But I burnt my clutch in about 1month after I went BPU. I got a TRD clutch too Its superb a little heaver clutch pressure but it grips like hell. Also It has that on/off feel cause its a quick release clutch and rattles after it gets a little hot at idle. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 23, 2002 Share Posted September 23, 2002 TRD clutch is the same as an RPS one apparently but more expensive because of the name.... Quote Link to comment Share on other sites More sharing options...
Alex Posted September 23, 2002 Share Posted September 23, 2002 PHR do an upgrade to the actual gearbox I believe... Ring and Pinion set which reduce the ratio's to give better acceleration...i think Quote Link to comment Share on other sites More sharing options...
eyefi Posted September 23, 2002 Author Share Posted September 23, 2002 Originally posted by Alex Holdroyd PHR do an upgrade to the actual gearbox I believe... Ring and Pinion set whats that? Quote Link to comment Share on other sites More sharing options...
Alex Posted September 23, 2002 Share Posted September 23, 2002 No idea!! Have a look at the description on the site.... Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 23, 2002 Share Posted September 23, 2002 Originally posted by Alex Holdroyd No idea!! Have a look at the description on the site.... Your honesty is admirable! Quote Link to comment Share on other sites More sharing options...
Gordon F Posted September 23, 2002 Share Posted September 23, 2002 Originally posted by Alex Holdroyd Ring and Pinion set which reduce the ratio's to give better acceleration...i think This sounds like the final drive (diff) gears. Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted September 24, 2002 Share Posted September 24, 2002 It changes it from the US spec 3.13 to the j-spec 3.27 so it is preety pointless doing this to a j-spec 6-speed as there is no difference. Could be done on a UK spec though. Quote Link to comment Share on other sites More sharing options...
eyefi Posted September 24, 2002 Author Share Posted September 24, 2002 syed, where d u get these numbers from? Quote Link to comment Share on other sites More sharing options...
paulrenn Posted September 25, 2002 Share Posted September 25, 2002 I'd be tempted to keep the stock Toyota clutch to be honest. A little bit of slip is good for keeping your drivetrain in good condition...a harsh clutch could break your gearbox/driveshaft etc if you dump the clutch with a major amount of power...for example when drag racing...and stock Toyota performance clutches are usually pretty good. The only upgrade I'd really consider for clutch would be a Helix one from Fensport, but dunno if they have a Supra application. Just IMHO... Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted September 25, 2002 Share Posted September 25, 2002 Originally posted by eyefi syed, where d u get these numbers from? Just while reading through http://www.mkiv.com This means that while the j-spec can do 196mph, the UK spec can hit 205mph Quote Link to comment Share on other sites More sharing options...
GavinL Posted September 25, 2002 Share Posted September 25, 2002 Originally posted by Alex Holdroyd Ring and Pinion set which reduce the ratio's to give better acceleration...i think or is that more wheelspin Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted September 26, 2002 Share Posted September 26, 2002 Originally posted by paulrenn I'd be tempted to keep the stock Toyota clutch to be honest. A little bit of slip is good for keeping your drivetrain in good condition...a harsh clutch could break your gearbox/driveshaft etc if you dump the clutch with a major amount of power...for example when drag racing...and stock Toyota performance clutches are usually pretty good. The only upgrade I'd really consider for clutch would be a Helix one from Fensport, but dunno if they have a Supra application. Just IMHO... I don't know whether this theory really applies to the Supra with it's dual mass flywheel assembly. This is exactly the reason that they put the dual mass flywheel in place, to reduce the shock to the drivetrain when you do release the clutch. Quote Link to comment Share on other sites More sharing options...
Adam W Posted September 26, 2002 Share Posted September 26, 2002 You'll only mince the transmission if you fit a total "overkill" clutch. The important thing is to get one with a sprung hub - this means that as the driven plate bites onto the flywheel, there are circumferential springs which let it rotate slightly independantly of it's hub, hence reducing the shock to the gearbox input shaft. The hub (which is directly connected to the gearbox) gets a moment to "catch up" to the speed of flywheel as the springs compress. Hard to explain in words but if you saw a picture of one you'd understand! Steer clear of race spec stuff like (for example) the Clutchmasters Stage IV clutch, four paddle brass button unsprung driven plate = ouch. Unless you have a race spec gearbox, propshaft, diff, and driveshafts of course! Quote Link to comment Share on other sites More sharing options...
eyefi Posted September 27, 2002 Author Share Posted September 27, 2002 heres a selection of the cheaper end of rps's clutch selection (taken from their web site):- model.....part#.....list price $.....torque cap.....pressure incr SPORT SERIES street disc 93+.....SS-22170-ST.....$549.00.....525.....10% solid hub puck 93+.....SS-22170-SH.....$589.00.....600.....10% sprung hub puck 93+.....SS-22170-SP.....$595.00.....600.....10% MAX SERIES street disc 93+.....MS-22170-ST.....$687.00.....660.....38% solid hub puck 93+.....MS-22170-SH.....$707.00.....825.....38% sprung hub puck 93+.....MS-22170-SP.....$747.00.....825.....38% is the torque capability figure the amount of torque it would take to slip the closed clutch? if so would i see any real benefit from anything other than a street disc, considering my engine torque is not gonna b above 525lb/ft? and am i correct in thinking that the max series street disc is just gonna give me a heavier clutch? how long do these clutches last? standard fast road use, the odd high rpm launch etc sorry for all the questions, im new to performance transmissions. ta Quote Link to comment Share on other sites More sharing options...
WRC-Biturbo Posted October 6, 2002 Share Posted October 6, 2002 Hello 400 to 450Ps on flywheel is too much for org. Clutch my car have 443Ps / 629NM on the Flywheel and the new org. Clutch where brocken after 3000KM at the time i built in a Qs- Giken Triple Clutch including Flywheel the weight is loosing 17 Kg to org. Clutch & Flywheel. The clutch is loud and not easy to handle but there can do 1000 RWHP and many torque. In future i make a turbo upgrade so i do one of the best clutch´s on the market. here some pictures from the clutch: http://supras.bei.t-online.de/Kupplung%20neu.jpg http://supras.bei.t-online.de/Kupplung/scheibe%2011.JPG here a picture of the dynorun please forgive my bad englisch http://supras.bei.t-online.de/Pr%fcfstand.jpg please forgive my bad englisch best regards Thomas Quote Link to comment Share on other sites More sharing options...
randy Posted October 6, 2002 Share Posted October 6, 2002 Hi Thomas! What car was this dyno taken for? Date says 1980? Pretty impressive figures! Quote Link to comment Share on other sites More sharing options...
randy Posted October 6, 2002 Share Posted October 6, 2002 Thomas, Don't worry about your English! Its fine!!! Nice to have more Europeans on board. Quote Link to comment Share on other sites More sharing options...
WRC-Biturbo Posted October 6, 2002 Share Posted October 6, 2002 Hello The owner of the dyno have the wrong date in the computer, the dyno was done at April this year. I am really happe with the clutch because is the best for street racing and with a little bit time and traning you can drive it easly for every day. best regards thomas Quote Link to comment Share on other sites More sharing options...
randy Posted October 6, 2002 Share Posted October 6, 2002 Thomas, Was this for the Supra or the Subaru? Quote Link to comment Share on other sites More sharing options...
WRC-Biturbo Posted October 6, 2002 Share Posted October 6, 2002 Hello Randy What for a Subaru??? :( The clutch is built in my supra. i never ownerd a subaru. best regards thomas Quote Link to comment Share on other sites More sharing options...
randy Posted October 6, 2002 Share Posted October 6, 2002 Sorry mate! I just thought from your sig-WRC thinking WRX? Anyway what mods do you have on your car to get 443ps? How much harder is the pedal pressure on the the OS Giken? Got any pics of your car? post em. Quote Link to comment Share on other sites More sharing options...
