markybhoy86 Posted March 9, 2009 Share Posted March 9, 2009 right this is becoming a pain in the arse, rear of my supra is still clunking so far i have; checked the subframe bolts changed the bootrubbers changed the droplinks changed the passengers side rear bearing had the rear struts stripped and checked all bushes are good no excessive play what do i do now? im completly lost!!! Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted March 9, 2009 Share Posted March 9, 2009 Diff mate. Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 9, 2009 Author Share Posted March 9, 2009 what you mean?anything i can check? Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted March 9, 2009 Share Posted March 9, 2009 well i had a clunking once and found that the little metal clip that holds the brake pad had fallen/taken out so every time i drive the pad was moving around etc. hence the clunking noise. check the brakes first. then get the diff checked, Homer and JamieP should be able to give you the best direction as Homer knows them inside out and Jamie is a master at destroying them. Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 9, 2009 Author Share Posted March 9, 2009 the noise only happens when i go over bumps. getting the bearing changed removed some of the noise (sounded like a clatter before) now its just a bump bump lol am shit at describing things but i try my best lol some more ideas please Quote Link to comment Share on other sites More sharing options...
Gordon F Posted March 9, 2009 Share Posted March 9, 2009 Get a proper 4 wheel alignment done. Worked for me Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 9, 2009 Author Share Posted March 9, 2009 full wheel alignment has been done recently and i havn't changed anything since then to throw it off much Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 9, 2009 Share Posted March 9, 2009 You checked the subframe bolts but did you check the bushes? Or was that part of "all bushes". I had the same problem but only over a specific type of bump, turns out the forward right hand bush was fecked. Any handling issues? Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 10, 2009 Author Share Posted March 10, 2009 handling has been feeling good, it was crabbing a bit before i got the tracking done but that is sorted now. r u meaning the bushes that the subframe bolts tighten onto? Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted March 10, 2009 Share Posted March 10, 2009 handling has been feeling good, it was crabbing a bit before i got the tracking done but that is sorted now. r u meaning the bushes that the subframe bolts tighten onto? bud lol! im guaranteeing you its the stupid brakes!!! i had exactly the same issue, every time a little hump, pot hole etc. id hear a nice little knock from the back, it was a moving pad because like i explained before it was a little metal clip missing that holds the pad in place in the calliper. the clip is on the calliper and not the one on the pad, the pad has its own one. Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 10, 2009 Author Share Posted March 10, 2009 no bother i'll give that a look over 2night, u got a drawing so i can see what part your talking about? Quote Link to comment Share on other sites More sharing options...
Scott Posted March 10, 2009 Share Posted March 10, 2009 I had this in the MR2, it was driving me absolutely insane. Turned out to be the exhaust bouncing off the sub frame lol. Where did you get your alignment done? Thats the next thing on my to-do list. How much was it? Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 11, 2009 Author Share Posted March 11, 2009 its not the exhaust checked that. got my alignment done at "the garage" http://www.the-garage.co.uk was 75 they did the whole lot, aligment camber toe n wotever else its called. thers another place in bonnybridge called progrip think he does it for 55, the same stuff, havn't used him yet but i've heard good things about him Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 12, 2009 Author Share Posted March 12, 2009 right i had a look at the brakes they're doesn't seem to be anything wrong that i notice. do supra's ever suffer from the springs hitting off each other? i know mine has Tein springs on it and they're pretty close to each other- not sure what shocks are on, they look like standard ones to me. just another idea?im running out Quote Link to comment Share on other sites More sharing options...
movistar Posted March 12, 2009 Share Posted March 12, 2009 get someone with an nvh testing kit to have a look...we have one here at work and they are great for detecting whines, rattles ect Quote Link to comment Share on other sites More sharing options...
Paul372 Posted March 12, 2009 Share Posted March 12, 2009 diff, change the diff oil see what comes out quick easy job, if you have lots of bits of metal teeth stuck on the magnetic plug and in the oil then good guess the diff has gone, i found this out with mine Quote Link to comment Share on other sites More sharing options...
markybhoy86 Posted March 12, 2009 Author Share Posted March 12, 2009 right i'll get the diff oil changed over the weekend and let use know the outcome. anyone know of a nvh testing kit in scotland?lol Quote Link to comment Share on other sites More sharing options...
