supra-ireland Posted March 8, 2009 Share Posted March 8, 2009 Hi- My car has a full decat and Turbo's capable of producing 2.0 bar (allegedly). I want to restrict the turbos to prevent damage. From what I've read I think I should be putting a 1.0 bar restrictor ring between the 1st and 2nd decat pipes. Is this correct? Is this enough to prevent damage? Are all 1.0 bar restrictor rings for Supra's the same or is there a particular version that I should be buying. -Cheers, Paul Quote Link to comment Share on other sites More sharing options...
couv3z Posted March 8, 2009 Share Posted March 8, 2009 not sure about a 1.bar RR, i have a 1.2 from envy, but from what i understand you don't know if it will be a 1.2 it could range depending on mods and the RR itself it could allow you to boost to 1.3 or 1. you never know till its on the car and you see the gauage Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted March 8, 2009 Author Share Posted March 8, 2009 Ok cheers mate. Well can someone recommend a good restrictor ring then, that should hopefully keep my boost pressure down to a safe level? Quote Link to comment Share on other sites More sharing options...
Rich Posted March 8, 2009 Share Posted March 8, 2009 Yeah,get a 1.0 bar chris wilson one. Ideally get an egt gauge to monitor the exhaust temps and an afr gauge would also be nice to monitor the air fuel ratio. Quote Link to comment Share on other sites More sharing options...
snake Posted March 8, 2009 Share Posted March 8, 2009 you will need a restrictor ring to reduce boost pressure after decat.Then you need a boost controller so you can set the correct boost pressure,Then it's a good idea to have a boost gauge to keep an eye on it. Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted March 8, 2009 Author Share Posted March 8, 2009 I've got an Apexi air/fuel controller but don't have time to get it installed at the minute. I've got a boost gauge already in. I'll buy a 1.0 bar restrictor ring and stick it in for now. Quote Link to comment Share on other sites More sharing options...
Jake Posted March 8, 2009 Share Posted March 8, 2009 My car has Turbo's capable of producing 2.0 bar (allegedly). 2 Bar? Blimey. What turbos are they? Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted March 9, 2009 Author Share Posted March 9, 2009 2 Bar? Blimey. What turbos are they? Stage 3 Hybrids. I said allegedly because I know feck all about it and that's just what I was told they're capable of producing. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted March 9, 2009 Share Posted March 9, 2009 Stage 3 Hybrids. I said allegedly because I know feck all about it and that's just what I was told they're capable of producing. Wouldnt believe that for a second to be honest. Hybrids on here usualy go between 1.4 and 1.6 and then eventualy blow themselves to bits a few 10k miles later Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted March 9, 2009 Author Share Posted March 9, 2009 Wouldnt believe that for a second to be honest. Hybrids on here usualy go between 1.4 and 1.6 and then eventualy blow themselves to bits a few 10k miles later Thanks for the information. Quote Link to comment Share on other sites More sharing options...
