Dave F Posted March 7, 2009 Share Posted March 7, 2009 Replaced a rear hose on my girlfriends Corsa so need to bleed the system. I have a fair amount of dot 5.1 fluid in the shed, do you think I could use this or should I go and buy the dot 4 fluid which I think is the standard stuff. Cheers Dave Link to comment Share on other sites More sharing options...
DannoSupra Posted March 7, 2009 Share Posted March 7, 2009 Dot4 Its not a good idea to mix up brake fluids Link to comment Share on other sites More sharing options...
3LL Posted March 7, 2009 Share Posted March 7, 2009 DannoSupra said: Dot4 Its not a good idea to mix up brake fluids Link to comment Share on other sites More sharing options...
Dave F Posted March 7, 2009 Author Share Posted March 7, 2009 Must admit I wouldn't mix but have more than enough to do a complete change as its not been changed for a couple of years. Link to comment Share on other sites More sharing options...
merckx Posted March 8, 2009 Share Posted March 8, 2009 (edited) Dot 5.1 brake fluid is compatible and can be mixed with dot 4. Dot 5.1 is a more expensive and a higher spec fluid with higher boiling points than dot 4 . If you had to buy some in the shops you would obviously go for the dot 4 as it's cheaper and it meets all the requirements for a Vauxhall Corsa braking system and most other road going cars. But if you've already got some dot 5.1 it can be used. Edited March 8, 2009 by merckx (see edit history) Link to comment Share on other sites More sharing options...
movistar Posted March 9, 2009 Share Posted March 9, 2009 What ever u do dont bleed it using the brake pedal..u will screw up your master cylinder...best to pressure bleed these dave. Brake fluid looks like its been covered.... Link to comment Share on other sites More sharing options...
Dave F Posted March 9, 2009 Author Share Posted March 9, 2009 Ahhh cheers for that fella. Just got to find the kit now, I know its somewhere in the shed after trying it on the Supra to find it wouldn't fit Link to comment Share on other sites More sharing options...
