Corsa brake fluid
Dave F
Replaced a rear hose on my girlfriends Corsa so need to bleed the system. I have a fair amount of dot 5.1 fluid in the shed, do you think I could use this or should I go and buy the dot 4 fluid which I think is the standard stuff.
Cheers Dave
Dot 5.1 brake fluid is compatible and can be mixed with dot 4.
Dot 5.1 is a more expensive and a higher spec fluid with higher boiling points than dot 4 .
If you had to buy some in the shops you would obviously go for the dot 4 as it's cheaper and it meets all the requirements for a Vauxhall Corsa braking system and most other road going cars. But if you've already got some dot 5.1 it can be used.
Edited by merckx (see edit history)
