supradibbs Posted March 6, 2009 Share Posted March 6, 2009 Anyone know how much grunt to give these nothing in the manual Quote Link to comment Share on other sites More sharing options...
Steve Posted March 6, 2009 Share Posted March 6, 2009 The setting is known as FT I know when i did mine up it actually broke the socket. This link may help http://www.mkivsupra.net/vbb/showthread.php?t=35927&highlight=front+subframe Quote Link to comment Share on other sites More sharing options...
michael Posted March 6, 2009 Share Posted March 6, 2009 http://www.mkivsupra.net/vbb/showthread.php?t=35927 Quote Link to comment Share on other sites More sharing options...
dandan Posted March 6, 2009 Share Posted March 6, 2009 (edited) Here's the page from the manual: http://mkiv.com/manual/manualtt/general_maintenance/mo14.jpg Ref the rear subframe bolts: There is a slight contradiction in the manual as the diagram shows a different torque value to the text Edited March 6, 2009 by dandan (see edit history) Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 2, 2009 Share Posted June 2, 2009 Just to try and clarify things 100% are the 125Nm bolts all the 17mm ones? and the 200Nm ones the 19mm ones? Its just that the diagram (to me at least) is not that clear and underneath there seem to be some numerous 19mms bolt heads (flush with the under side of the car and not requiring a deep socket or extension bar) then x2 19mm nut heads way up in the alloy subframe and a few other 17mm nut heads similarly up higher within the subframe (extension and deep socket required) The only ones ive done up to 200Nm are the bolt heads that rear most and flush with the underside..............is that correct or should some of the others be 200 too? Quote Link to comment Share on other sites More sharing options...
Homer Posted June 2, 2009 Share Posted June 2, 2009 The only ones ive done up to 200Nm are the bolt heads that rear most and flush with the underside..............is that correct or should some of the others be 200 too? It's been a long time since last doing this, but it's the set of 2 at the front of the front subframe which have 125NM, the set of 4 at the back of the front subframe are 200NM. Well, thats the way I read it at least! Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 2, 2009 Share Posted June 2, 2009 cheers do you remember doing the nuts that are up within the subframe.............they are nuts on bolts (captive i think) that come down from above and to see them you have to be almost directly underneath them? Quote Link to comment Share on other sites More sharing options...
Homer Posted June 2, 2009 Share Posted June 2, 2009 cheers do you remember doing the nuts that are up within the subframe.............they are nuts on bolts (captive i think) that come down from above and to see them you have to be almost directly underneath them? IIRC, I did them all from underneath, including the ones up in the frame, the wheels need to be under full weight while torquing up so lowered the front wheels onto some blocks (only enough to get underneath to put as much weight as normal on the car). Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 2, 2009 Share Posted June 2, 2009 the wheels need to be under full weight while torquing up ah bollocks thought that only applied to the suspension arms etc! will have to retorque them tomorrow! Quote Link to comment Share on other sites More sharing options...
Homer Posted June 2, 2009 Share Posted June 2, 2009 ah bollocks thought that only applied to the suspension arms etc! will have to retorque them tomorrow! Not sure how much difference it makes but have followed this since Mark (ex-Pheonix) told me to do up all bolts under static load. I'd imagine they'll be under-tight rather than over if done up while the subframe is not under load. Quote Link to comment Share on other sites More sharing options...
